HP OfficeJet 4215 All-In-One InkJet Printer Logo
Posted on Jan 25, 2009
HOW DO I GET OFFLINE INTO READY ON MY PRINTER
How do I get offline to ready on my printer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
267
Points
Make sure that usb cable is connected between the computer and printer if printer is usb printer.
After this right click on printer icon and click on option use printer online after this printer will be ready for printing.
2answers
Why is My Brother Printer MFCJ82DW Offline?
Your Brother printer can be offline, most probably when it is not set as default printer on your computer. Let's take a look at the steps on how do I get my brother printer back online. First, right click on the printer icon in your computer. Go to what's printing and click on printer. Then, remove the check mark in front of use printer offline. The status of your printer would be now back online and ready to print.
https://connectmyprinter.com/how-to-fix-brother-printer-offline-error/
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
Keeps telling me the printer is offline
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
Update drivers: recommended links
http://windows.microsoft.com/en-US/windows-vista/Update-drivers-recommended-links
Source: Samsung SCX 5635FN Manual
My printer says it is online and ready to print but when I go to printers and faxes in control panel it says it is offline and will not print.
Right click on t he printer; you will see an option for work offline and a check mark next to it.
Click on it and you should be ready to go.
Hope this helps!
PRINTER "OFFLINE" FROM PC CONTROL PANEL, PRINTER SCREEN READY
Make sure you have the ethernet cable plugged into the printer/network and is working properly. The toner replacement doesn't affect the network functions of the printer
5helpful
2answers
Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
k24674
Grand Canyon Tech
Grand Canyon Tech
