Belkin (F5D7230-4) Router (587009) Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belkin wireless router not assigning IPs for wireless clients
My router has been working fine for 3 years..
2 days ago, wireless clients are unable to obtain an IP address, the pool is 192.168.2.2-9 and instead is assigning 169.254.14.3, of course not valid.
RJ45 connected clients are fine, they get .2 and .3
No firmware updates have been available for a while, nothing changed, tried rebooting/reset router, play around with wep 24, mac filtering etc...same... did the router go south???
It's a Belkin Wireless Cable/DSL Gateway Router (no model number)
Anonymous
Level 3:
  • Master 585 Answers
  • Posted on Jan 10, 2009
Anonymous
Master
Level 3:
Answers
585
Questions
Helped
257408
Points
1678
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
1helpful
My Roku is not finding my belkin router. It used to work. suddenly it doesnt. I
If its an older belkin, they have been known to go bad around 3 years, have to buy a new router. I lost all my wireless and that solved all the problems.
Belkin g wireless router not able to connect or 192.168.2.1
u said u have static IP for ur internet. if these IP's are already assigned in ur computer, ur computer will not be able to accept an IP from the router. so u 1st u need to remove the IP's that are already assigned in the computer's LAN properties. keep the option as"obtain an IP address automatically". then u should be able to open the router set up page using 192.168.2.1
Is there a way to exclude IPs from the DHCP Pool? I can't find an advanced setting. I fear I have bought a POS. I have many devices on the network and need to have them maintain the IPs I have assigned...
I'm afraid you are right.
On this router, you can only enable or disable DHCP in general, but not set the range used for DHCP.
Sorry to be the bearer of bad news...
You could try to set your static IP's in the upper range (192.168.2.254 and down) because DHCP usually starts at the bottom range (192.168.2.2 and up). I know this is not an ideal solution, but it might work for you depending on the number of clients you have.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Problems with my Belkin N1 router since we have 1 PC on Vista
to solve this problem you need to set up static IPs on your LAN clients. Whether your SIP provides you with a static IP or not makes no diffrence you can still assign one to each machine on your network and that should solve the problem.
Belkin 54G works OK with wireless connections but not wired!!!
In the end I replaced the ethernet cable with another one and it worked!!! That simple....................
2answers
WEP to WPA
Ok, access your routers web management page.
From the menu on the left, select Wireless, then Encryption.
You should be able to change the settings there.
As im sure your aware, you will have to reconfigure the other 5 clients to use WPA after doing this. I would recommend having a least on client connected by ethernet to the router so that if changes make the wireless inaccessable, you can still access the routers configuration.
Wireless Router
Greetings...
Here are the steps to hopefully get you reconnected...
SymptomNot able to connect to the router/AP wirelessly, or intermittent wireless connection.
ResolutionTo address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
Have a great day...
Ed
Belkin f5d7632uk4a v4
hi dear
1. Try and uninstall the Belkin client software
2. Check to see if the WZCSVC service is running
You can check this by issuing the following command:
a) net start
b) sc query wzcsvc
Both command should list some info about WZCSVC (Wireless Zero
Configuration) if it is running.
3. If your wireless card is installed successfully, you should see a
antenna-type icon in the system tray.
If not, you need to install the drivers for the card manually. Check
the Belkin CD for drivers.
4. If you can see your new router's SSID (wireless name) then you should be
able to see it as a non-admin as well.
5. Failing all of this, retry the Belkin client software and its
documentation for indication on non-admin issues or ways to use the above
mentioned Windows wireless client.
oke
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
2answers
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
