Problem
You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause
Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution
Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Causes And Symptoms Of Canon Error 5100:
Canon error 5100 means the printer is not recognized by the computer. This error message is basically displayed with LED blinking. It adversely affects your printing task. Besides this, it also generates various other problems as well. Therefore, proper measure is essential to settle the issue as soon as possible. However, resolving the issue should require a minimum number of technical knowledge. So, if you find it difficult to resolve the problem on your own. Then, seeking experts guidance would be nice step to take. Contact our experts at Canon support who are experienced enough to resolve the issues in no time.
Smart Tricks To Eliminate Error Code 5100 From Your Canon Printer:
It is always better to take experts help to remove the error. But in case you want to resolve the problem all by yourself, you can try the steps that are given below:
§Turn off the printer and unplug the power cable attached to your printer, and wait for some time.
§Press and hold the power button, and restore the power
§Depending on your firmware, you may also have to press and hold the resume button, simultaneously. At this point, you may get a buzzing sound.
§While continuing to press the power button press the resume button twice as well, in short bursts. Now, release the power button.
§Again, depending on the firmware, you may have to press the resume button three more times
§Now, press the power button once. Further, if you got a single buzz before, you should get one too even this time, indicating you have exited programming the firmware
§Now, the printer will switch off automatically
The steps mentioned above might help you to resolve the error. But if you are not a tech-savvy person, you might face difficulty in performing the task for sure. Hence, reach our experts immediately for better clarification of the steps. The professionals of our team will provide you with step-by-step direction to help you out with the issue in the right way.
If You Still face the problem Kindly Visit Us, we'll solve out your every problem:
Our Website Link: Canon Printer Error 5100
Our Toll-Free No- +1-888-209-3034
SOURCE: error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and
turn off the printer. While pressing the Resume/Cancel button, press
the Power button. (Do not release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3)
While holding the Power button, press the Resume/Cancel button three
times, and then release the Power and Resume/Cancel buttons. (Each time
the Resume/Cancel button is pressed, the LED lights alternately in
either orange or green, starting with orange.) During initialization,
the LED blinks in green.
4) When the LED stops blinking and
lights in green, press the Resume/Cancel button the 4 times. (Each time
5) Press the
Power button. The LED lights in green, and the selected function is
performed. (When the operation completes, the printer returns to the
menu selection mode automatically.)
6) Power off then back on and test.
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
SOURCE: canon printer MP160 error 2 also MP460 error 5100 any help?
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
265
SOURCE: Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
