Printer will not work as it says"ensure rear access panel is properly closed" Back panel IS securely closed as normal.
SOURCE: Paper Jam and Won't feed paper
This is the pickup guide....
It is replaceable but you should take it to an authorized HP repair center.
Look for a commercial printer repair company in your area.. not a local computer kid.. this is a part that must be ordered by a guy with certifications.. otherwise.. you void the warranty.
If this printer is under warranty.. give HP a call and ask them if they can send a replacement.. I will warn you though.. they'll want to troubleshoot and give you a hard time to avoid sending a replacement... if you have patience and stamina with people... you can try and i wish you the best.
If it's too much.. it might jsut be easier to buy new and donate the poor printer.
Best wishes. www.techvisitor.com
SOURCE: rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
