Error message I/O card parity interrupt at F000:E1AD. Type (S)hut off NMI, (R)eboot, other keys to continue
Try running the Check Disk Utility. To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
SOURCE: I have a D620 Laptop.. when i turn on my Laptop i
try going into the BIOS of your system upon powering your laptop as soon as you see your Dell Logo keep on tapping f1 till you get a different screen or if the system beeps when you tap on f1 then stop it should boot into your system BIOS and give you options,
normally for dell it should have a phoenix BIOS try setting your bios to defaults then save and exit the bios if still it does not fix you issue then you can try reinstalling windows and its drivers .
