Brother MFC 420CN All-In-One InkJet Printer Logo
Anonymous Posted on Nov 19, 2011
Error message, print requests stuck in que
Just get a message an error has occurred with a small yellow triangle with exclamation mark inside. Printer cable is fine (purchased a new one and still didn't work), ink is full.
Brian Sullivan
Level 3:
  • Brother Master 27,725 Answers
  • Posted on Nov 19, 2011
Brian Sullivan
Brother Master
Level 3:
Answers
27725
Questions
Helped
5670421
Points
79191
You might have multiple prints loaded
make sure you have the printer turned off it might load another page to be printed
you will need to open up a page you are about to print click ok
a page will open with a display print que tab
you will see all of the prints you have loaded
right click on the ones you dont need select delete
hope this helps
1helpful
Doro Flip Phone. I have a red triangle on text messages on my phone?
Question edited for clarity.
Question moved to a better category.
Hello Maurice
questions like this really need to model number of model name. Doro make lots of flip phones. There are various ideas here in the links below.
Remove battery to reset.
Your data usage is exceeded.
The text wasn't sent.
What does an exclamation mark in a red triangle next to a text ...
https://www.cellphones.ca > answers > what-does-it-mea...
Oct 9, 2014 - What does it mean when there is an exclamation mark in a red triangle next to a text message? It shows part of a text when I open it up none ...
Red Exclamation point...... - HTC Droid Incredible - Android ...
https://androidforums.com > ... > HTC Droid Incredible
May 4, 2010 - The red triangle with the exclamation mark is showing up because somewhere in the string of texts you've been sending to this person, you did ...
16 posts · It comes up when sending text messages. Not in the messaging widget, but when you actually ...
W\hat does it mean when i see a red exclamation - Fixya
https://www.fixya.com > Forum > Cell Phones
Nov 20, 2019 - Hello, Normally, the red spot on an envelope in the sent messages means that your text has not been delivered to the destination phone number the text was sent ...
1 answer · 3 votes: Hello, you don't have to be bothered my friend,the red exclamation sign simply indicates that the message is broken along the way which means the message ...
SOLVED: Hi, my husband has a Doro 508,a big red ...
1 answer
Sept 16, 2019
SOLVED: Red triangle appears when text message sent ...
1 answer
May 14, 2015
How do i get rid of red exclamation mark on text ...
1 answer
Aug 21, 2014
What's the red triangle symbol on the android - HTC ...
1 answer
Apr 7, 2011
More results from www.fixya.com
What does the red triangle mean beside my "sent message?
https://forums.androidcentral.com > ask-question > 590...
Oct 5, 2015 · 3 posts · 3 authors
As keyree said, it means the message has not been sent. You should be able to tab the message and hit resend or retry. 10-06-2015 03:50 AM.
Meaning of Exclamation Point in a Triangle - texting ...
Aug 23, 2010
how do i get rid of the red triangle with the exclamation ...
Feb 19, 2016
More results from forums.androidcentral.com Missing: Doro ‎' Must include: Doro
How to remove the triangle with exclamation mark ... - AskingBox
https://www.askingbox.com > question > how-to-remov...
Oct 31, 2013 - The symbol "triangle with exclamation mark" in the status bar is a common symbol for a warning. In your case, that is the data usage warning.
I’m getting a box with a yellow triangle above it with an exclamation mark in it on my toshiba tv. Help
Could you please let me know the model number of the TV? This should be printed on a badge or strip on the back panel. Please also describe the warning - i.e. the message and error code displayed. Thanks.
2answers
What does a yellow exclamation point inside a triangle warning sign mean. Now check engine light just came on.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
1helpful
Yellow triangle with exclamation mark permanently showing
This is the master warning light. It is a warning that another light is lit or a condition has occurred that requires review by the driver. If there is a driver information window a message may be displayed.
Example of other conditions depending on the car is:
  • Low tire pressure
  • low window wash
  • Low fuel warning
26143099-cuwo5vs5donv5atj0gwaggyx-3-0.jpg Hope this helps?
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
What is the warning with a Triangle and exclamation mark inside it
It means "something is wrong". You need to check the messages to find out.
Advanced Micro Devices ATI I/O Communications Processor USB 2.0 EHCI controller driver so usb ports will work
Would you please check the device status in the Device Manager? Is there any yellow triangle box with an exclamation mark in it?
Exclamation mark in facebook chat
There's an error.
I suggest that you close your facebook or browser and open it again. It just needs a refresh.
I hope this helps!
Carlo
1helpful
Samsung 1915 printer: the red light with the double artrows and the exclamation in a triangle is flashing. What's up? John
1. A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
or
2.Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner.
Printing error with PowerPoint
Reinstall the software from hp website and download the latest version. that will fix the issue. Before that what you can do is go to start-right clcik computer and go to propertoes and then go to hardware and then to DEVICE MANAGER.is you see any yellow triangles or exclamation marks . right clcik and update all the drivers. that will fix the issue.
Norman Weimar
Norman Weimar
k24674
