Put the flash drive into your computer's USB port (assuming you have the proper driver loaded onto the computer). Go to "My Computer" and highlight the drive that shows up, right-click and select "Format." That'll wipe it completely clean.
Or, if you just want to remove the files, do the same thing but instead of formatting, just highlight the files and right-click to delete the file, pix, or whatever.
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
65 questions posted
103 Questions
103 Questions
75 Questions
