20 Most Recent Verbatim VER95327 USB Hard Drive Questions & Answers
you can recover deleted files from external hard drive with asoftech data recovery software, you can download the software from
http://www.asoftech.com
Verbatim... | Answered on Feb 23, 2018
have you tried to re-format this USB?
Verbatim... | Answered on Mar 27, 2017
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Verbatim... | Answered on May 07, 2015
It sounds like the partition on your Verbatim drive is damaged but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Verbatim... | Answered on Jan 31, 2013
Im not sure what computer you have, but whenever I use an external hard drive on my computer, an icon either shows up on the toolbar, I dont think in your case thats happening or you would have obviously seen it, however if you have a start or home button on your toolbar on your regular desktop location then you can click to open your computer menu e.i. control panel, word, games,...etc.. look for your "computer" file, click to open, then look for "Hard Drives" or "Devices and Storage" also check and see if anywhere in those menus if there is a "Removable Devices and Storage" tab, if you find these menus and verbatim 53018 doesnt show up in any of your menu tabs then try creating a file on your computer and saving it to your hard drive in the "Save" file location, if its connected properly then you should see a message screen that asks you which location would you like to save your file, it should list all possible storage locations and hopefully Verbatim 53018 is listed.
Hope this helps you out.
Verbatim... | Answered on Oct 16, 2012
go to start go to control pannel click on hardware tools clcik on disk management and have it scan the disk if it still does not reconosie it get back to me and I will have a better solution for you.
Verbatim... | Answered on Apr 11, 2012
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
Verbatim... | Answered on Dec 19, 2011
click start right click on computer select properties then device manager scroll to universal serial bus controllers if you se a yellow question exclamation mark ? ! or a red X you will need to update/reinstall drivers right click select update drivers
once inserted windows 7 should automatically install the drivers
if you computer came with a motherboard disk the drivers could be on it
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem check the usb leads inside your computer usually
usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Verbatim... | Answered on Sep 06, 2011
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Verbatim... | Answered on Jun 08, 2011
I would check the pins in the end of the flash drive and see if any of them are bent back. If these metal pieces aren't in the right place then the flash drive won't be able to connect to your laptop. I would try bending them back into place with a small flat head screwdriver. If you don't want to fix it yourself then I suggest you either buy a new flash drive or take it to an electronics store for more help.
Verbatim... | Answered on May 03, 2011
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Verbatim... | Answered on Mar 31, 2011
install the drivers that came with the disc and it will work
Verbatim... | Answered on Mar 03, 2011
Ithink it could be due to virus activity. Some virus make the contents of thedrive hidden, that's why user can't see the files and the space available for use is less than thecapacity and also can not open the drive. It issuggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may showthe hidden files. If can not show ,hidden file (tools >folder option>view> check on show hidden file>check off hide protected and checkoff hide extension) now can see all hidden file in c drive. If not think...... For ensure again run>type> msconfig > hit can not open ms config if virus effected run >type> regedit>hit>can not open registry if virus effected run >type >gpedit.msc>hit can not open group edit policy if virus effected Otherwise, ifyou don't have any vital data on the drive, just format it in another pc.Pleasenote, before insert the Pen drive .Go to run command from start menu OR Press Win key+R and type gpedit.msc and hit>Usser configuration >system>turn off auto play >enable>use down arrow key select all drive >apply >ok. Control panel>administrative tools > service>select any word in right side and presss for select Shell Hardware Detection> d -click >use down arrow key>disable >start. And now can insert pen drive and format. Hope this wouldfix the issue and . Youshould fully scan by f-secure bootable cd or any another antivirus bootable cd.Just insert the disk and restart. Follow bellow the download link. http://www.f-secure.com/en_EMEA-Labs/security-threats/tools/rescue-cd you wouldbe able to enjoy the full capacity of the disk. Try to be sure follow these youshould delete partition and create new partition and format your all drive. Now install fresh O.S.
Hope this helps
Verbatim... | Answered on Feb 22, 2011
Verbatim VER95327 USB Hard Drive Logo
Popular Tags
91 questions posted
Top Verbatim Computers & Internet Experts
ChinthakaJ
ChinthakaJ
gggg
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Verbatim Computers & Internet
Most Popular Question
recover permanently deleted files from
  • Computers & Internet
