20 Most Recent Magnum DeltaForce CB Radio Questions & Answers
3answers
How to wire a Golden Eagle Astatic D-104 Mic to a RCA Cb Co-Pilot 14T303 4 pin connector
i have a gold eagle mark 4 i like two put a 776 mike back on it but i do not know the w coed .thank you .
6/14/2021 8:26:19 PM • Magnum... • Answered on Jun 14, 2021
6answers
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
9/20/2019 11:59:01 PM • Magnum... • Answered on Sep 20, 2019
2answers
Wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
7/7/2019 6:28:10 PM • Magnum... • Answered on Jul 07, 2019
How to calibrate a magnum delta force?
www.cbtricks.com has what you need.
7/17/2015 6:48:23 PM • Magnum... • Answered on Jul 17, 2015
My power supply mess up and started smoking now my magnum delta force cb is messing up when i turn it on the swr meter will light up but no sound and frequency counter wont light up any clue
Smoking means something died, possibly in the power supply so the result is incorrect or no power to the internal boards of the unit. Take for repair or replace the unit.
2/17/2015 1:17:07 AM • Magnum... • Answered on Feb 17, 2015
How fix talkback in magnum delta force
you need to check the audio path from the chatback board to the audio circuit usually the audio out the board will go to the center connection on the volume control sometimes people use a resistor to attenumate it to a level or a T pad and connect it to the left side {audio out to amp} so a volume control works like this left center right ground audio into control audio to amp so usually the center is used as the volume will track up as your sets volume is increased so simply connect the audio out from the chatback to the right audio to amp section on the chatbacks ive made and installed in the past had a small pot on the board this allows the volume from it too be increased so look for this first if you cant find it you can make one up like this 100K log pot 3 pin 1 2 3 L M R {left middle right} 1= ground 2= audio from chatback 3= audio to the right right audio to amp on the cb's volume control then no matter what level the actual audio from the set is set too the chatback can be set to a standard level for all hope this helps you i used too build chatbacks for the rnid year back and fit them free
12/2/2014 12:42:23 PM • Magnum... • Answered on Dec 02, 2014
Channel selector only works going down not up
there is two common connections to the channel selector up and down resolder the channel sectors pins then it will work its a broken connection to a common pin if its not a break on the selector to the PLL data bus then use DE-OXITE 50 {this one no others for selectors} look on ebay for it
11/30/2014 5:44:49 PM • Magnum... • Answered on Nov 30, 2014
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
7/30/2014 6:38:47 PM • Magnum... • Answered on Jul 30, 2014
I need wiring diagram for d 104 to yaesu ft 101
SHIELD & BLACK -1 WHITE -2 RED - 3 This is what my Astatic book says for Ft101's. Good luck
4/2/2014 5:33:54 AM • Magnum... • Answered on Apr 02, 2014
0answers
Wire diagram
Be the first to answer 3/4/2014 4:06:58 AM • Magnum... • Posted on Mar 04, 2014Be the first to answer
0answers
Carnt get it off pa
Be the first to answer 2/20/2014 3:19:02 AM • Magnum... • Posted on Feb 20, 2014Be the first to answer
Digital signal meter needs adjusting what vr number do i ajust
99% of export radios its VR8
2/4/2014 2:43:45 AM • Magnum... • Answered on Feb 04, 2014
No variable powere or am modulation
the "am" regulator is shorted. 2sa743 2sa1012or equivilent. less than $5 part..
2/4/2014 1:42:10 AM • Magnum... • Answered on Feb 04, 2014
Wire 4 pin microphone
  • Here is how it should be wired. --- Pin 1 -> Shield --- Pin 2 -> Modulation --- Pin 3 --> Transmit Switch --- Pin 4 --> Receive
  • PiP
  • 2/3/2014 7:12:48 PM • Magnum... • Answered on Feb 03, 2014
    0answers
    Cobra 148gtl off frequency on sideband transmit
    There is nothing that you can do without a test bench for frequency testing and tuning.
    1/25/2014 6:06:06 AM • Magnum... • Answered on Jan 25, 2014
    How do i wire a d104 desk mic to a madison base
    You don't mention if the Madison is a 4 pin or 5 pin also you don't mention if the D104 is a 4 wire or a 6 wire microphone so this will be rather lengthly of an answer so if I help you could you atleast do the rating for me ? So here goes 4 pin / 4 wire 1]SHIELD 2] WHITE 3] RED 4] BLACK....O.K. 4 pin 6 wire 1]SHIELD & BLUE 2] WHITE 3] RED 4] BLACK YELLOW NO CONNECTION.....Are you with me so far ? Half over 5 pin 4 wire 1] WHITE 2]SHIELD 3] BLACK 4]N/C 5] RED.....5 pin 6 wire 1] WHITE 2] SHIELD&BLUE 3] BLACK 4]N/C 5] RED.I hope this helps you GOOD LUCK and have a good day Dan.
    1/25/2014 1:26:44 AM • Magnum... • Answered on Jan 25, 2014
    Radio Communications Logo
    145 questions posted
    Top Magnum Radio Communications Experts
    eradiostore
    eradiostore
     Grubhead
    Grubhead
    Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Magnum Radio Communications
    Most Popular Question
    wiring diagram road king 56 4 pin mic
    • Radio Communications
