20 Most Recent
Sony BRAVIA KDL52XBR2 Television Questions & Answers
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
My Sony Bravia kdl32ex43b has 6 blinking standby
6 blinks denotes a fault with its main board.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
I have purchased Sony Bravia
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
I have a 32 V
This problem can be fixed by Qualified Technician.don't worry your LCD Screen is alright and this is not a big issue.
