20 Most Recent Samsung LN-T4061F 40 in. LCD HDTV Questions & Answers
My 40 inch Samsung Tv does not have a clear picture
try cleaning t-con board to lcd panel cable..........
if sam problem just replaced lcd panel
2/10/2019 3:10:24 PM • Samsung... • Answered on Feb 10, 2019
0answers
Tv will not turn on
My TV had a simular issue...delayed power-on with repetitive clicking. I found a post at Techreport.com about bad capacitors on the power board. This and other Samsung models seem to have an issue with these components failing. I replaced the capcitors myself last night, and the tv is now working perfectly. Cost me about $15 in parts and an hours time. Hope this helps!
3/31/2017 2:32:18 AM • Samsung... • Answered on Mar 31, 2017
0answers
How can i solve the problem of samsung 40s if its stuck in rca inputs video 1
Try a reset to this TV, and then check. If it do not help you, replace its main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
8/7/2016 12:26:30 AM • Samsung... • Answered on Aug 07, 2016
Need to fined/know the name brand remote control or code number for my LCD TV
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
7/15/2016 6:00:44 PM • Samsung... • Answered on Jul 15, 2016
My tv is not responding to either the cable-paired remote or its own remote. can only be operated manually.
Hi Ememobong, It seems the infra red sensor in your TV has gone bad. Please have it checked. Good Luck
5/5/2016 11:21:27 PM • Samsung... • Answered on May 05, 2016
I have a samsung LN-T4061f. It will begin flashing like a strobe light after a short time then the scren goes blank. I still have sound. I have done the turning it off using a power strip and that w
This set may have a separate back light inverter or it may be incorporated into the power supply. Here is the parts list: http://www.shopjimmy.com/samsung/lnt4061fx/xaa If you note, the power supply is out of stock. That is an indication that it is a common failure item.
3/17/2016 10:55:45 PM • Samsung... • Answered on Mar 17, 2016
I have a Samsung LN T4061f flat screen that has developed horizontal lines that happens on every input as well as effecting the menu. i tried adjusting all the settings and it seems to get a little be
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
11/29/2014 3:45:01 PM • Samsung... • Answered on Nov 29, 2014
2answers
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
7/23/2014 7:49:33 PM • Samsung... • Answered on Jul 23, 2014
Why won't my tv recognize the HDMI
It sounds that the HDMI firmware has not installed. Contact any service technician to re-install the firmware. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
5/16/2014 6:07:20 PM • Samsung... • Answered on May 16, 2014
Tv flickers non stop on all inputs
Flickering can occur by many reasons. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/21/2014 5:49:36 AM • Samsung... • Answered on Apr 21, 2014
Samsung LN-T4032H
This is the capicator $1.50. You have to take off the back, sauter off the capicator (you'll see it because it is poking out) and sauter on the new one. I found the fix on this web-site.
4/14/2014 6:37:21 PM • Samsung... • Answered on Apr 14, 2014
0answers
0answers
Samsung LN-T4061F 40 in. LCD HDTV Logo
230 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung ln t4061f flat screen developed
  • Televison & Video
