20 Most Recent Samsung LN32A330 32 in. LCD TV Questions & Answers
6answers
TV LED Polytron gambar hilang tapi suara ada, itu kenapa ya?
Hy nama sya febri
Saya ada tv led polytron , saat dalam keadaan mati tv saya nyala kan dgn remote tapi tidak keluar gambar sedangkan ada suara dan lampu nya. Lalu saya coba matikan dan hidupkan lagi tetap sama gambar tidak ada sedangkan suara dan cahaya ada, setelah beberpa kali saya on of percobaan ke tiga smpai ke 4 lalu tv menyala dgn normal... kira kira kendala nya apa ya...pls di kasih pencerahan
3/22/2021 3:54:40 AM • Samsung LN32A330... • Answered on Mar 22, 2021
How do I use mysamsung remote to correct the split screen on my tv
AmanStino Lightning Cable [Apple MFi Certified] 1M Nylon Braided Charging Cord - Black
AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
5/19/2020 9:07:20 AM • Samsung LN32A330... • Answered on May 19, 2020
2answers
Hi, power supply is not working
Can't say this for sure, but if it's a power supply problem, take the TV apart and access the power supply (unplug it, of course). Look at all of the capacitors (the little round cans with 2 wires either coming out the bottom or one coming out on either end). If they appear to be bulging (you can tell a good one from a bad one very easily), they're most likely bad and many times replacing those will solve your power supply problem.
11/8/2019 2:40:11 AM • Samsung LN32A330... • Answered on Nov 08, 2019
3answers
Samsung LN32A330J1N LCD T.V has no picture when powered on
This can be one of two problems. The backlight inverter board is bad # BN44-00235B <or A $60-80
Or one of your backlights is bad/broken. Not a easy repair. Single lamp is about $16-25 whole kit $150. But finding a great tech who can or will take the screen/light box apart to do it will be the biggest task. Takes about 3 hrs to do. And if you do NOT know what you are doing,you will damage the screen.
Then you just throw it away. But if your lucky, it might just be a bad connection. If it comes one after it goes off. But if it just flashes on for a couple seconds then does not come back on, Most likely bad backlight/or inverter. It goes in to protection mode.I have seen in a couple of Sony's it being the T-con board "LCD control"board do the same. $60-125
I wish I could give you better news. It is not easy to tell the problem on that without testing out each lamp "15-20 of them w/a lamp tester" or checking out each transformer on the inverter board. Verry time consuming. This is why I push the Extended Warenty. LCD's still have bugs to weed out. Plasma's are even worse.
11/8/2019 2:35:04 AM • Samsung LN32A330... • Answered on Nov 08, 2019
My samsung LN32A330J1 won't power
You need the capacitors on the power supply board replaced. Samsung is covering the cost to repair this problem on your model. Just call 1-800-samsung and they should set you up for repair.
11/1/2019 12:15:28 AM • Samsung LN32A330... • Answered on Nov 01, 2019
Samsung 32
Hello Alice,That is an indication of a failure in the back light inverter power supply. That model Samsung is covered under a class action lawsuit settlement. Samsung has agreed to repair all TVs with bad power supply board free of charge for parts and labor even if the unit is out of standard warranty. You will need to contact Samsung to arrange the warranty service on the unit. You can get full details and Samsung contact information here:http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/I hope this helps,BuddyMc
7/9/2019 4:28:57 AM • Samsung LN32A330... • Answered on Jul 09, 2019
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
6/27/2019 1:21:19 AM • Samsung LN32A330... • Answered on Jun 27, 2019
7answers
Hp samsung GT-E1080F ,lupa code
Berapa kode standart telephon SAMSUNG GT-E1080F
11/14/2018 5:53:15 AM • Samsung LN32A330... • Answered on Nov 14, 2018
Bought a used Samsung smart tv. Netflix still has precious owners account attached to Netflix. How do I remove it.
  1. Samsung Smart TVs ' Technology To Change Your Life ' samsung.com‎
    Adwww.samsung.com/UK/SmartTV‎ Quick & Easy To Use, The New Generation Of Samsung TVs Is Our Smartest Yet. Types: Quantum Dot Display, SUHD Nano Crystal TVs, UHD Nano Crystal TVs, UHD TVs, HD TVs Edinburgh · 1 retailer nearby
Search Results Remote Control Method
  1. Press the "Up" arrow key twice on your TV's remote control while in the Netflix app.
  2. Press the "Down" arrow key twice.
  3. Press the "Left" arrow and then the "Right" arrow. ...
  4. Press the "Up" arrow four times. ...
  5. Press the arrow keys to navigate to the "Deactivate" option, and then press the "Select" button.
How to Log Off of Netflix on a Samsung TV ' It Still Works ' Giving Old ...
https://itstillworks.com/log-off-netflix-samsung-tv-23508.html
10/31/2018 8:15:57 AM • Samsung LN32A330... • Answered on Oct 31, 2018
I have a samsung tv UN50h6201 no sound no picture. I believe I need a new power supply. The power supply has the LED driver integrated on the power supply.
moved you from computes to TV ok? well it can be any board seen inside, did you look first? power supply or logic boards. with no test equipment?, all you can do is guess. so start with the cheapest part. make sense?
10/8/2018 9:40:12 PM • Samsung LN32A330... • Answered on Oct 08, 2018
My un60f7100 Samsung shutdown 2 or 3 times and after that its ok its only on start up
MY TV It will get worse. if it self shuts down make sure vents at rear are call clean.
10/5/2018 9:36:32 PM • Samsung LN32A330... • Answered on Oct 05, 2018
My netflix won't connect to mt Samsung TV. I can watch on my Mac no problem
hello: wifi , is not reliable. use Etherent cable from TV to router ! wins !you posted TVs to Computers, so will move you.what TV o TV model stated.MAC, how is it connected, to your router? all that tells me is the internet works on the mac. as does its browser..I will assume the TV shows, can not connect to local LAN , errors, (wifi in this case) gee use Ethernet cable.not netfix login failure not like me using 3 TVs to netflix, with a 2 TV max same time account. Also Netflix, Hulu and Vudu all 3 no longer supportold TVs running those old streaming apps with same name.they do not, (buy ROKU3 , wired)The went to a far better, streaming protocal your TV does not support, but again, NO TV even stated.By a long ethernet cable.no distance from TV to Router stated, nor type of walls between them,(concrete /brick horrible)WIFI is radio technology at its base) and weak signals.you skipped test 1;use ethernet, cable.this proves the TV works the TV app works and that Netflix, likes all that, with one simple test.a $10 cable, sold in all computers stores on earth.NO TV stated, full model on the rear sticker is it.lots of TV made in 10 years ,even olderand old is bad, in the realm of , Smart screen apps that are relics now.
9/20/2018 1:07:42 PM • Samsung LN32A330... • Answered on Sep 20, 2018
I have a Samsung tv model no Ssg 4100 GB ...I cannot connect to Netflix . Etc ...any reason for this
moved you to TV out of computers the model i picked is wrong but fixya is not samsung at all. and only few models indexed. smart TV sure, well do all the other streaming apps all fail too? if yes then the internet connection is bad. dont use wifi, it is hard to use, and very weak , slow and can overload easy for sure lots of neighbors on same wifi channels. so use ethernet cable cat 5/6 connect it to the router from TV to Router direct wired, see it does work, and now you know why it didnt before (WIFI sux deal)
9/18/2018 12:25:13 PM • Samsung LN32A330... • Answered on Sep 18, 2018
2answers
Samsung tv stops streaming Netflix’s and freezes
I'd be looking at your internet speed. Sometimes when there are a lot of users at the same time the speed is reduced that will cause that. Have your provider test the modem to see if it is passing the speed you're paying for.
9/12/2018 1:12:32 PM • Samsung LN32A330... • Answered on Sep 12, 2018
Where do you get and how much is a power supply board?
A model and make would help
12/29/2017 2:10:53 AM • Samsung LN32A330... • Answered on Dec 29, 2017
0answers
LN32A330
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
11/13/2017 11:51:45 AM • Samsung LN32A330... • Answered on Nov 13, 2017
Samsung LN32A330 32 in. LCD TV Logo
467 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung ln32a330j1 power
  • Televison & Video
