20 Most Recent
Asko W6461 Front Load Washer Questions & Answers
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models
If the coin trap in the drain is clear of debris, try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
F6 - error message
My W6461 keeps repeating the cycle, doesn't shut off. Anyone experience this?
The Washer makes a loud Chirping sound while in Wash Cycle
Hi dear,
You can do followings to identify what could be faulty.
1- Unplug it from power
2- Remove back cover and careful of sharp edges
3- take off the drive belt
4- Rotate drum pulley and motor shaft by hand. See if one of them makes that noise
5- Basic explanation The noise indication of bearings wear and tear. I hope that helps.Thanks.
Doesnt fill with water
CHECK THE WATER PRESSURE SWITCH. AND INLET WATER VALVE. MY BET IS WITH THE INLET VALVE. CAN CHECK IT WITH A METER FOR OHMS OR CONTINUITY. THEN
fuse a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Hello, I have an ASKO Washer model W6461 and I
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
