20 Most Recent Asko W6021 Front Load Washer Questions & Answers
3answers
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
3/5/2022 1:36:19 PM • Asko W6021 Front... • Answered on Mar 05, 2022
2answers
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
10/21/2021 6:08:20 PM • Asko W6021 Front... • Answered on Oct 21, 2021
Asko W6021 won't start
change the carbons theres nothing wrong with the board
1/6/2019 6:38:14 PM • Asko W6021 Front... • Answered on Jan 06, 2019
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
11/20/2018 2:57:41 AM • Asko W6021 Front... • Answered on Nov 20, 2018
The pin trap will not screw back into the washer
Check you have not pushed anything into the pump, also clear any limescsle away
2/2/2018 7:03:54 PM • Asko W6021 Front... • Answered on Feb 02, 2018
Door is stuck.
as we don't know what the lid or plug mean got to the nearest washing machine repair person and explain to him and get an answerer as from him as we cant see your predicament with our own eyes, sorry to put it blunt but that's the only answerer eric
1/2/2018 10:17:50 PM • Asko W6021 Front... • Answered on Jan 02, 2018
Asko washer w6021: returned to laundry room to find power button depressed, but indicator light dark.
try the fuse in the plug the sometimes go without warning eric
12/27/2017 11:44:41 PM • Asko W6021 Front... • Answered on Dec 27, 2017
We have a w6021 Asco washer it will neither drain
Most likely the water pump is clogged or damaged
9/7/2017 4:16:50 PM • Asko W6021 Front... • Answered on Sep 07, 2017
The detergent drawer is jamming and extremely difficult to open,any suggestions please?
Hi I would think its probably built up detergent in the runners take the whole drawer out and give a good clean use a steam cleaner if u have one
6/23/2017 6:07:40 AM • Asko W6021 Front... • Answered on Jun 23, 2017
My ASKO washing machine will not go through its regular cycle
it may need the carbons in the motor replaced part no 8801195, is it pumping out the water if it doesnt the door wont release.
2/20/2017 7:29:14 PM • Asko W6021 Front... • Answered on Feb 20, 2017
3answers
Front drain plug
I have similar issues with my Asko W660. Once it was a key stuck between the inlet to the pin trap and the trap itself. I got it out by jiggling and poking into the trap area with a narrow strip of plastic. Mostly, though, it just requires a stronger grip on the door to the pin trap--the little handle is slippery, and hard to get a good grip on. Try making a grip out of a piece of duct tape, or grabbing the handle with pliers.
8/14/2016 7:31:47 PM • Asko W6021 Front... • Answered on Aug 14, 2016
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in the problem is most likely in the program board not progressing the wash cycle
7/12/2016 11:19:00 PM • Asko W6021 Front... • Answered on Jul 12, 2016
How long should wash cycles be? mine have gotten longer
Not an UNCOMMON complaint Rosemary Stein, On the new machines "suds-sensors" control the "efficiency" of your machine... If you check you OWNERS MANUAL I'm pretty sure You need to run good grade "HE" detergent... The reason being the "suds-sensors" will get messed up with BARGAIN detergents & become MORE IN-EFFICIENT. Contemporary wisdom says "If you stop now and run some cleaner in your machine you can avoid costly serve charges". Hope this helps!
5/6/2016 1:34:44 PM • Asko W6021 Front... • Answered on May 06, 2016
2answers
How can I open detergent drawer, opens about 20mm & won't come out any further
Pull the drawer out as far as it goes then lift it up and pull it out completely. It may be stacked due to detergent remainings. So, you should clean the drawer with a soft brush under warm running water. Do not put the drawer into a dishwasher! Replace the drawer by tilting it into position. Hope it helps.
3/31/2016 6:09:47 PM • Asko W6021 Front... • Answered on Mar 31, 2016
My Asko Machine, After a wash cycle clothes still wet. Not spining. water does not drain.
If you put it on spin only cycle does it spin up?
9/11/2015 3:14:10 AM • Asko W6021 Front... • Answered on Sep 11, 2015
0answers
3answers
Cycle takes forever and water not heating
FIRST OFF CHECK WITH A MULTI MTER FOR CONTINUITY. THE WATER TEMPERATURE CONTROL SWITCH, THE INLET VALVE, AND UR SO CALLED ELEMENT WHICH I FIND ODD AS HAVENT SEEN A WASHING MACHINE WITH A HEATING ELEMENT B4.
4/3/2015 4:13:07 AM • Asko W6021 Front... • Answered on Apr 03, 2015
Water will not drain
CLOGGED HOSES OR BAD WATER PUMP
4/3/2015 12:52:11 AM • Asko W6021 Front... • Answered on Apr 03, 2015
Asko W6021 Front Load Washer Logo
336 questions posted
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Asko Washing Machines
Most Popular Question
asko w6021 start
  • Washing Machines
