20 Most Recent
Walgreens Automatic Wrist Blood Pressure Monitor Questions & Answers
WE HAVE A WALGREEN BP
You can obtain and Owner's Manual by contacting the manufacturer, HoMedics at 800-466-3342.
Thanks for choosing FixYa.
8/5/2011 8:54:55 PM •
Walgreens...
Answered
on Aug 05, 2011
The cuff appears to be
E3 error code is an Error Determining Measurement Data. This can be caused by movement of the wrist, hand or arm during the measuring function. In which case, sit very still with your wrist at heart level, until the measuring cycle has completed.
If this continues to happen, contact HoMedics (the manufacturer) Customer Support Dept at 800-466-3342.
Hope this helped you. Please let me know.
5/12/2011 8:35:47 PM •
Walgreens...
Answered
on May 12, 2011
My wrist cuff monitor seems to be reading low. Is
The next time you go to your doctor, take the wrist cuff monitor with you. As they always do, the nurse or doctor will check you vital signs. After they do that and they've told you what your blood pressure and pulse readings are, correctly place the cuff monitor on your wrist and check you BP and Pulse with it. Compare the reading from the cuff monitor to what your doctor got. If it's within a few points, it's no big deal. If it's way off, than there's a problem with the cuff.
Remember, whenever using a cuff monitor, always keep your wrist at heart level for the most accurate reading. Once it's activated, remain completely still and don't move your wrist, until it has finished cycling.
2/23/2011 2:43:57 PM •
Walgreens...
Answered
on Feb 23, 2011
How do I delete previous
1. Press the User-Select Button to select User 1 or User 2.
2. Press and hold the button that looks like it has a clock face on it and the + buttons at the same time, while in the Memory Recall Mode and the data for the selected user will be deleted automatically.
Hope this helps to answer your question.
2/19/2011 9:53:41 PM •
Walgreens...
Answered
on Feb 19, 2011
Reset my Walgreens digital weight scale
Im not familiar with the Walgreens brand scale, but with most digital scales, you use the following procedure to reset.
Step on the scale to turn on. Then step off. The scale will reset itself and read 000. Then step back on to get your weight.
Now, if for some reason it doesn't come back to 000, turn it over and remove the battery(s). Leave out for a minute to allow the electronic capacitors to drain. Then reinsert the battery and go through the process above to set 000.
