20 Most Recent
Walgreens Wrist Blood Pressure Monitor Questions & Answers
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Walgreens digiital blood pressure monitor model
Since that BP Monitor has a 5 year warranty. Your best bet is to contact HoMedics (the manufacturer) Customer Support @ 800-456-3342. That's assuming you replaced the old batteries with new one's out of a in date package and all are placed properly.
I use the Walgreens digital blood pressure
Wherever you attach it - there must be a pulsating artery; Some people have atypic artery locations, old embolism with collateralisation (arterys everywhere except the place you think they are). Try another arm/leg/finger. Try it on your husband/nice/neighbour. Look if the marterial has a defect - then the error occurs in anybody, or if it measures accurately in the postman and not in you _ then you must look for a,other place to measure. If you have cardiacabnsolute arrhythmia or a lot of backfires (extra systoles): forget electronic measuring devices. Buy an old one with a stethoscope
Err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
Reset my Walgreens digital weight scale
Im not familiar with the Walgreens brand scale, but with most digital scales, you use the following procedure to reset.
Step on the scale to turn on. Then step off. The scale will reset itself and read 000. Then step back on to get your weight.
Now, if for some reason it doesn't come back to 000, turn it over and remove the battery(s). Leave out for a minute to allow the electronic capacitors to drain. Then reinsert the battery and go through the process above to set 000.
