20 Most Recent
Walgreens By HoMedics Automatic Wrist Blood Pressure Monitor 1ea Questions & Answers
What does error code EP
you should be able to clear the code by removing the battery, and by the way does it have new good batteries?
We have WGNBPW-510 Automatic Blood
To delete the history first, press the User-Select Button. Then press and hold what looks like a tiny button clock and the + button to the right of it at the same time, while in memory recall mode and the data for that selected user will automatically be erased.
Hope this helps you.
Reset Walgreens BP cuff model wgnbpw-520
Press user select to choose 1 or 2. Press the M button to pull up memory and then press both top buttons at the same time to clear. Display reads CLA if done properly.
I NEED AN OWNERS MANUAL
As a 30 year EMT, I think I can help you.
There's 2 numbers that make up your blood pressure. The top number is called the Systolic pressure. The bottom number is call the Diastolic pressure. When a blood pressure is taken, it's measuring the pressure that the heart is producing when it pumps blood through the arteries. For example, what's considered a normal blood pressure in a healthy individual is in the range of 120/80. Of course age, life style and other health conditions, play a role in what yours may be. A person with High blood pressure or Hypertension would have a blood pressure of over 160 - Systolic and over 90+ Diastolic. 90 is actually the borderline for hypertension. That's why I indicated 90+.
The other reading on your monitor is your heart rate or pulse rate. It's how many beats your heart completes in one minute. It also indicates an irregular heart beat by the showing a small LED window on the left of the screen adjacent to the Systolic pressure reading, It will say IHB. Any movement or shaking or talking during the measurement can result in pulse irregularities. So hold very still when taking your blood pressure. This irregularity by itself is not of much concern, unless it shows up frequently. In which case, you should seek medical advice.
That covers just about all there is to know about what the readings mean. Armed with this, you should be able to effectively monitor your blood pressure and pulse rate and report them to your doctor.
Hope I was able to help you understand how it works and what it's telling you. if so, please let me know, by rating my response to you. Thanks and have a healthy day.
