20 Most Recent
Walgreens Ultra Deluxe Inflate Blood Pressure Monitor Questions & Answers
Reset my Walgreens digital weight scale
Im not familiar with the Walgreens brand scale, but with most digital scales, you use the following procedure to reset.
Step on the scale to turn on. Then step off. The scale will reset itself and read 000. Then step back on to get your weight.
Now, if for some reason it doesn't come back to 000, turn it over and remove the battery(s). Leave out for a minute to allow the electronic capacitors to drain. Then reinsert the battery and go through the process above to set 000.
Why does my Walgreens digital blood pressure monitor keep giving an ERR4 message?
Here are the top 3 reasons for getting errors: 1. You're using the wrong-sized cuff. If you are extra large, you need a larger cuff. 2. You've incorrectly positioned your body. Ideally, your arm should be at the level of your heart. 3. You've placed the cuff incorrectly. Make sure the cuff is on your upper arm and the stethescope is placed over the place you feel the strongest pulse. I hope that helps!
