20 Most Recent RCA P52960 52" Rear Projection Television Questions & Answers
Television set wont turn on .
labor and parts are around 200.00 us dollars.
5/31/2016 7:13:34 AM • RCA P52960 52"... • Answered on May 31, 2016
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me [email protected].
3/10/2015 4:29:03 PM • RCA P52960 52"... • Answered on Mar 10, 2015
0answers
2answers
The picture is bigger than the screen... Picture
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
3/18/2014 9:18:33 PM • RCA P52960 52"... • Answered on Mar 18, 2014
. I have a RCA Home Theatre Premiere Modle P52960. I have gone through the convergence procedure and it worked well. I now need to adjust the vertical size so round objects on the screen are not elong
Problems can be solved only by direct contact with the company and follow-up with them for a moment by moment
1/25/2014 7:17:21 PM • RCA P52960 52"... • Answered on Jan 25, 2014
0answers
0answers
Reset
Be the first to answer 6/17/2013 5:13:22 PM • RCA P52960 52"... • Posted on Jun 17, 2013Be the first to answer
What is the problem when the screen shows a red screen
The red CRT has an issue and will need replacement.
4/3/2013 12:24:30 PM • RCA P52960 52"... • Answered on Apr 03, 2013
RCA Home Theather TV will not power on.
Check your breaker panel, might of triped the power.
12/25/2012 7:57:28 PM • RCA P52960 52"... • Answered on Dec 25, 2012
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
12/22/2012 2:53:12 AM • RCA P52960 52"... • Answered on Dec 22, 2012
My rca d52w26 convergence is gone.
Look in the on screen menu for convergence and if it is not there you have a open ( bad ) protection part on the main board, a kit exists for most of these sets for this===buttons alone will not likely help here.the convergence menu missing is a result of this and the part in question is often bad because of bad solder connections.If you need more info let me know.
8/28/2012 12:39:37 PM • RCA P52960 52"... • Answered on Aug 28, 2012
RCA P52960 goes black
does the audio still work? If so I would suspect the vertical out IC
8/7/2012 4:37:14 PM • RCA P52960 52"... • Answered on Aug 07, 2012
POWER SUPPLY NEEDED FOR EYEFI LX 4700 TV
Hi.About your EYEFI power supply. Did you check the blue electrolytic capacitors on the P.S. board? I have a power supply board here for the same tv. There are 6 of the 35 volt /2200uf capacitors. They all look like they have been a little overheated on the top of them.If you look at the top of them real close and compare it to a good one somewhere else on the board you might see a difference in thier appearance. The top of the canister should be extremely flat and the blue wrap around it should not be stretched.On mine it is slightly noticable that these 6 capacitors ar beveled and the blue wrap is stretched some and I think if I replace them it will work.I have done this kind of work for many years then got out of it.I'm getting back into it because I like doing flatscreens. It would be alot cheaper for you this way. I haven't located a parts place yet to order them. They have a white silicone around them and maybe thats because they get really hot. I don't know a flatscreen that likes too much heat or too much moisture for that matter. There is a place that has these power supplies for sale but he is out of themright now and personally if it's more then 50 bucks it's a rip His are 49.99 w/free ship.Don't let anyone tell you that because EYEFI went out of business that you can't find these There is a guy on ebay selling them for 139 bucks/frigin rip off. I told him good luck with that..lol. Anyway hope this helped. If you find one cheaper and in stock please let me know. Thanks and good luck. Lisagee:)
6/15/2012 12:24:51 PM • RCA P52960 52"... • Answered on Jun 15, 2012
I have a RCA 52960 SRS Focus, Rear Projection. Also I have Directv, Would it make a differance if i got a High Def. From Directv ? Or is the TV High Def ?
Google the model number with specs to get an idea of what set has or does not have.
6/12/2012 8:56:12 PM • RCA P52960 52"... • Answered on Jun 12, 2012
How do i get the pip, Picture in picture to work ??
If it has the feature buttons on the remote for it, swap, position etc.Some older sets have to have signal routed to one of the rear video inputs for a source for the PIP. Newer sets have two tuners--one for main and one for PIP---if pulled up the swap will switch one picture for the other--some allow both on the screen at same time side by side.Read the owner manual to see if the set has PIP.
6/12/2012 8:54:18 PM • RCA P52960 52"... • Answered on Jun 12, 2012
Rca rear projection model # P52960..will not come
Replace the flyback transformer and HOT tarnsistor. You can get the Repair kit from www.tvrepairworld.com which has the Flyback and Hot
10/13/2011 1:17:21 PM • RCA P52960 52"... • Answered on Oct 13, 2011
RCA P52960 52" Rear Projection Television Logo
171 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
get pip picture in picture work
  • Televison & Video
