20 Most Recent
Samsung C410W Xpress Network-Ready Wireless Color Laser Printer Questions & Answers
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
My printer spoler is not working
Hi g k,Have you tried restarting the print spooler from services?Start the Print Spooler service from the Services console
- Click Start, click Run, type services.msc, and then click OK.
- Right-click the Print Spooler service, and then click Stop.
- Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
- Click Start, click Run, type cmd, and then click OK.
- Type the following commands at the command prompt:
net stop spooler
net start spooler
exit
Note Press ENTER after each command line.
Hope this helps, and please rate:)Gary
