Fixed skimmers are good for small bodies of water that don't have a surge tank. Performance of fixed skimmers will change depending on the height of the water. Overflow gutters don't. But if the body of water is large and you do have a surge tank then overflow would be better. ..
http://www.aurorapoolsandspas.com
CHECK TO SEE IF THE IMPELLER IF GOT TRASH IN IT..IS THE STRAINER BASKET CRACKED ? IF SO REPLACE IT ...AND HEAR IS HOW THIS PUMP COMES APART
IS THERE AIR IN THE BASKET ? TRY REMOVING YOUR FILTER , THE PRESSURE GAUGE MUST BE WORKING IT TELLS YOU WHEN THE FILTER NEEDS TO BE CLEANED
