20 Most Recent
Elkay Arezzo Single Lever Kitchen Faucet Brushed Chrome Pictured in Chro Questions & Answers
I have an elkay arezzo faucet, and within the last
There is probably a filter on the nozzel. This filter needs to be unscrewed, turning it to the left. Once removed the turn the fitting over in your hand and if needed, gently push the filter out. Once it is out you should be able to run it under the water flowing out and it small particles of crud should just wash out. Replace the cartridge, screw the fitting back onto the nozzel, turn on the water and see if the flow improves. Most modern faucets have some sort of screening filter arrangement in the nozzel ends. This is to restrict the flow of water somewhat as a water conservation effort. These screens can clog even if you think your water is clear, over time they are apt to slow the rate of water flow way down. BE SURE the water is turned off when you unscrew and replace the end of the nozzel otherwise you will get quite a bath! Good luck!
Manuel for I r installation
Try Googling or search for it online with the model number and name of sink. The brand name website would most likely have it.
9/1/2014 4:40:29 AM •
Elkay Home
Answered
on Sep 01, 2014
Water fountain elkay model # edfp17c
Feel the water coming out of it to determine if its the cold water side of the hot. More then likely you broke something and to determine what it is will require you to remove it. Home Depot has sink bolt removal tool that makes it much easier. After you find where the problem is then contact manufacture and usually they will send you free parts to fix or complete new one.
5/1/2014 2:38:41 PM •
Elkay Home
Answered
on May 01, 2014
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
2 days ago
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
My sloan flushmate toilet makes
this has already been answered on another site click here
http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
- Remove the ceramic cover from the tank on the back of the toilet.
- Fill a one-gallon jug with water.
- Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
- Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM •
Home
Answered
on Mar 14, 2024
