20 Most Recent
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Questions & Answers
Left red button has to be constantly reset. Also, water gets extremely hot
It should be producing hot water at the temp it was set at such as 120-140 degrees. If it is exceeding this one of the safety devices maybe disconnecting it. Thermal control might need some servicing. See what temp it's set at then put a thermometer on a near water outlet to see what's going on. Good luck.
Change o ring
I just tried to replace one of the o-rings on an AE125. The old original one came out distorted do to the fact that there's no groove to hold the o-ring in a uniform position.
Even though I was careful and evenly tightened the cap screws,
the new o-ring started leaking an hour after I had left the job.
My opinion is the mounting of the metal lid to the plastic tank is a bad design.
Good luck on your repairs.
Bosch PowerStar125 won't heat and I can't get one element to work
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
Bosch AE125 no hot water, blinking light
Hey Andy. Do you have your owners manual? There should be a section near the back that will break down the diagnostic code the flashing light is giving you. If not remove the front cover and look inside should be a wiring diagram and light legend.
