20 Most Recent
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Questions & Answers
Is a knob that won't tighten on hayward pump normal wear and tear?
it is possible that the knob was overtightened. check the slipping knob to see if there is a crack in the shaft. the other option is that it is stripped.
either way, it will not be considered normal wear but you should be able to find a replacement knob at your local store
My hayward 1hp super pump
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Skimmer won't circulate
If you are still having problems please post more info. Does circulation seem normal at pool inlet returns? Do you have full prime at pump?
Need to wire pump to switch
take a picture or two of your pump and wiring and go to your local ace hardware. so yes you can but it takes a high amp switch, and some extra fittings and a box to hold the switch. jay
