Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
Posted on Aug 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recording Late I have multiple weekly timed recordings set up - yet, it never fails they never start recording on-time. For example - it is supposed to start recording at 6pm and it might start instead at 6:09 or 6:55 - then it still records for the scheduled amount of time (so, records for 1 hour even if it starts 45 min late). It is never the same amount of time that it starts late, it NEVER starts actually on-time and it does this whether the HDD is totally empty or not. Do you have any suggestions?!? . . .
tom walsh
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on May 18, 2009
tom walsh
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
102254
Points
559
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
I had a new dvr added to my TWC cable services,but installer did not totally explain how to record or find recordings after taping. Can anybody tell me how to remedy this problem?
http://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/iguide/how-do-i-record-a-show-using-m.html
How do I record a show using my DVR and i-Guide?
There are multiple ways to do this:
  1. Press the RECORD button on your remote control while watching a program to begin recording. An overlay will appear on your screen to let you know you have started recording.
  2. From the TV listings grid, highlight the show you want to record and press the Record button.
  3. From any program information screen, highlight the Record icon and press the OK/Select button on your remote to schedule a recording. Follow the on-screen prompts for additional recording options.
Manually schedule a recording for a specific time or channel:
  1. Press the MENU button on your remote control then select the DVR icon.
  2. Or, if available, press the My DVR button on your remote control.
  3. Select the start time, end time and day that you want to record.
  4. Press Confirm.
  5. In the channel list that appears, select the channel to record from.
  6. Select Record to confirm your settings or select Recording Options for additional options.
and:
Video:
How to video DVR
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
My dish network dvr stops recording some programs, i think its just shows that are to be recorded on tv 1. It will record only like 10 minutes or less and stops recording
jeff_rhondac,
Check the timers you have setup for the programs that are suppose to record. Make sure the timers are setup correctly. Do you have any timers setup to begin early and end late? A new software update rolled about 2 weeks ago. Did you start experiencing the problem after that? Also, how much available time is available on the HD? Please let me know so I can further assist you.
Thanks,
Ray Calo
DISH Internet Response Team
My vcr wont record when programed but will if you just push the record button
When you set the timer see if PDC appears. If it does switch it to off and try setting a record. PDC sometimes doesn't work. And the recorder will sit there waiting for the signal to tell it when to start recording. Which never comes! However you will have to set the time to adjust for it not recording late running TV shows. For example a show to start at 8pm and finish at 8.30pm, will need to be set at 7.59 till 8.35pm. Or you could miss the start or end! Wheras PDC would get it all even if it started at 8.05!
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
2answers
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
1helpful
Timer programming problem
Check to see that you have not changed the default choice for input on power up of the box the "timeshift default device". If you have it set to front or rear CVBS or S-video input, it may ignore the channel choice you make when setting up the recording.
tom
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Vcr won't record on timer
when you set the timer you need to ok the settings of the programme you record then you need to switch the video off on the controll as it will only record in standby mode cus if the video is switched on it will wait for you to tell it to record hope this helps
2answers
Set a timed recording
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
