20 Most Recent Polaroid 1720-7 Remote Control Questions & Answers
24answers
Code for polaroid tv
I just got a new directv receiver...dvr....the codes for polaroid were not listed on the unit but were included in the booklet that came with it. They are as follows....10765,10865,11262,11276,11314,11316,
11326,11327,11328,11341,11498,11523,11991,11992
These were all listed for Polaroid. Hope this helps.
8/26/2022 8:36:45 AM • Polaroid 1720-7... • Answered on Aug 26, 2022
My polaroid tv remote isnt working
Get a new remote or try it again with new batteries.
8/17/2017 12:55:48 AM • Polaroid 1720-7... • Answered on Aug 17, 2017
Will this code work on remote for bt
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
4/8/2016 7:57:28 PM • Polaroid 1720-7... • Answered on Apr 08, 2016
Polaroid tlu01911cu remote code
I have one like this and found out its code is 0486 as a TV on a Silvercrest programmable remote
3/24/2014 11:57:07 PM • Polaroid 1720-7... • Answered on Mar 24, 2014
There is power but now picture
This is not a fault with remote control. It's with the TV. Contact any service technician. Gopakumar Gopalan Google
3/3/2014 3:07:36 PM • Polaroid 1720-7... • Answered on Mar 03, 2014
0answers
I need the code for a Polaroid 32" hdtv TLX- 44214B
0343. Try this code. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
2/9/2014 2:36:12 PM • Polaroid 1720-7... • Answered on Feb 09, 2014
Code needed for acoustic solutions dvd-237
0038,0033,0031,0039. Try these codes. For more information http://electrohelponline.blogspot.com/
11/26/2013 12:07:07 PM • Polaroid 1720-7... • Answered on Nov 26, 2013
Polaroid tv tdm1311 wont connect to cable
follow this steps and fix it. Use the digital or cell for to see the LED ON when you hit any keys.otherwise open and clean it.God bless you The batteries are dead. Replace the batteries. There is something blocking the receptor on the main unit. Remove any obstructions and clean the area in front of the receptor. The remote is too far from the receiver or at too extreme of an angle. Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver. A fluorescent or other bright light is shining on the receptor on the main unit. Turn off the light or shield the receptor. The device has a keylock or lockout feature turned on. Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature. Either the remote or the receptor on the device is not functioning. Use an Intraed Sensor to see if the remote is sending a signal. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed. If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost. f0f0a9e7-fd4f-4b49-80b9-a370d8f924a4.jpg
9/28/2013 12:58:13 PM • Polaroid 1720-7... • Answered on Sep 28, 2013
Tv de 14" con dvd. quiero saber que control es compactible polaroid
Try these codes. it just worked form me. 10765,10865,11262,11276,11314,11316, 11326,11327,11328,11341,11498,11523,11991,11992
4/8/2013 2:08:44 PM • Polaroid 1720-7... • Answered on Apr 08, 2013
Polaroid rc 103 wont program
please use this secret take you r. control point upward the digital camera( you must get one) turn on the camera and from the display you must see the diode LED iluminating. see the picture ilustration. If not working you must open the r. control and clean the keypads for dirty, corrosion, grease. fix it.God bless you2_19_2013_12_46_52_am.jpg2_19_2013_12_47_14_am.gif
2/19/2013 12:47:20 AM • Polaroid 1720-7... • Answered on Feb 19, 2013
Televison & Video Logo
107 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
rc 103 remote
  • Televison & Video
