20 Most Recent Polaroid FLM-3232 Television Questions & Answers
Same issue....went to bed last night Polaroid tv worked fine....woke up NO VOLUME>>>
Polaroid... | Answered on Mar 15, 2019
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Polaroid... | Answered on Sep 10, 2017
Menu closes when trying to scroll to HDTV to scan the channels: Wondering if you ever had a reply to this issue as I've been online reading several forums and still haven't found an answer. I've seen this topic a few times on this site and all of them have had "0" solutions/comments. Very frustrating.
Polaroid... | Answered on Aug 25, 2016
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Polaroid... | Answered on Jan 21, 2016
the lcd control board is out side the control box, its probably the culprit, its under 20 dollars new. the swollen cap means that its getting too much voltage to that component. better do voltage checks on the power supply each transformer is labelled for voltage output make sure its providing the correct voltage and not surging, this can cause the tv to fail with serious problems. now mr zuzu13 you need to have the tv on a surge protector and be careful not to let it arc when plugging in. you also need to do the same checks as above its most likely a power supply problem causing the shut downs. also reset your tv to factory settings by punching in 8282 on the remote this might also solve your problems. but dont forget to check the power supply now it might save you a costly repair.
Polaroid... | Answered on Jul 03, 2014
You could do 2 things:You can buy the big chrome control box for about $160 or you could take the control box apart and replace the main board for alot less money.Usually there are 2 boards inside the power and inverter are on the same board then the main board with all the RCA jackson it is the one to replace.
Polaroid... | Answered on May 27, 2014
Check its back light. Replace the back-light inverter; if found faulty. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Polaroid... | Answered on Jan 18, 2014
try One of them will work 11654 11223 11886
Polaroid... | Answered on Sep 16, 2013
If you're talking about the RCA L32HD31R,you take out 3 screws from the bottom of the stand
Polaroid... | Answered on Jul 04, 2013
you have a power supply problem.. I have fixed serveral tvs with this problem. normally you have to replace busted capacitors in the power supply board.
Polaroid... | Answered on May 10, 2013
Polaroid FLM-3232 Television Logo
260 questions posted
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
anyone know unirversal remote brand
  • Televison & Video
