20 Most Recent Polaroid FLM-3734B 37 in. LCD HDTV Questions & Answers
5answers
37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
12/6/2022 5:25:59 PM • Polaroid... • Answered on Dec 06, 2022
34answers
37" polaroid lcd tv won't turn on
First, I am no tech, this is at your own risk! I have a flm-373b which is out of warranty 15mths. A nice paper weight. Plug it in, blue light, no picture or audio. So I got the service manual and started taking it apart. Pulled out the so called control box and at the top is what appears to be some sort of power inverter board. I looked closely and saw that there were 2 capacitors that looked damaged. One was bulged and the other looked like it had popped. They were side by side, green and marked 1000Uf 10v. I took the board to work with me and unsoldered the capacitors and very carefully replaced them with 1000Uf 16v caps. This was just a crazy chance. When I got home I put everything back together, ran 2 extension cords to the back porch and plugged it in. The tv came on faster than when it was brand new. Now I have waited 3 weeks to post this, just in case my house burned down, but the tv is still working great. Again this is at your own risk. Polaroid is not helpful and they want you to spend more money to correct their problem which will probably not correct anything. I really do wish you luck with this or with putting up with polaroids BS.
- m@tT
3/7/2019 3:15:13 PM • Polaroid... • Answered on Mar 07, 2019
0answers
Polaroid TV
Be the first to answer 3/13/2017 12:06:02 PM • Polaroid... • Posted on Mar 13, 2017Be the first to answer
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
6/17/2015 7:30:12 PM • Polaroid... • Answered on Jun 17, 2015
8answers
37"polaroid FLM-373B
Hey guys, I read the solution about replacing the 10v 1000muf caps in the power supply module. I was ready to throw the set out. I tore apart an old old old Jerrold 700 converter and found a couple of caps that were 1000muf. One was 26v and the other was 52v. Anyway, the set works great now and I now have a 37" LCD in my shop to watch the Leafs!!!!
Thanks for the advice.
StereoSteve.
7/28/2014 6:27:37 PM • Polaroid... • Answered on Jul 28, 2014
Just put in new power supply board .was working maybe 10 minutes and it went out. Power supply does turn on and off with remote. What could be the problem?
possible inverter board bad or bad main board. disconnect inverter board and see if set comes on..if it does then inverter board is bad..if it does not then suspect main board.
7/3/2014 1:10:01 PM • Polaroid... • Answered on Jul 03, 2014
Flm-3738 polaroid powers up no picture
Have you tried it in mono audio?? Our TV seems to be shorting out with the right speaker.
6/1/2014 4:11:38 AM • Polaroid... • Answered on Jun 01, 2014
0answers
Panasonic tc-p42x1 powesupply board change and still have 9 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given.
3/15/2014 7:44:48 AM • Polaroid... • Answered on Mar 15, 2014
No picture but has sound
if it has sound but no picture, check this.. shine a strong flash light on the screen in various angles, you may see some signs of a picture. but it most likely sounds like the CCFL inverter has gone bad.. usually bad caps.. hope this helps you...
3/14/2014 1:34:01 PM • Polaroid... • Answered on Mar 14, 2014
I have a proscan and when you are watching a show,the channel goes to channel 4 and the blue screen with the words"signal" come up and I have to hit input and it goes to TV and I have to put it back
It has a faulty processor. Unfortunately this TV won't be worth fixing. Put up with it for as long as you can .
3/1/2014 10:04:56 PM • Polaroid... • Answered on Mar 01, 2014
0answers
4answers
Polaroid FLM373b No power.
When the filter capacitors went out , the power supply will feed AC instead of DC into the circuit board and may have damaged other circuits. Do you get the 5vdc standby voltage? it should be on one of the power supply out put connector the minute the you plug in the TV, you must have this before go further.
12/9/2013 4:55:17 PM • Polaroid... • Answered on Dec 09, 2013
Polaroid FLM-3734B 37 in. LCD HDTV Logo
Popular Tags
359 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
proscan when watching show channel goes
  • Televison & Video
