20 Most Recent Samsung VR3607 VHS VCR Questions & Answers
There is a problem with the loading basket, or the VHS tape is stuck inside and the eject mechanism can not cycle the tape out. To check this, open the lid so you can see the tape, if it is wrapped around the head and roller, hit the eject button to see if the tape is being pulled or jammed, cut the tape with scissors to free it up to see if it will pop out. If the tape is okay, it means you have a faulty loading basket.
Samsung VR3607... | Answered on Dec 30, 2010
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Samsung VR3607... | Answered on Feb 18, 2009
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Samsung VR3607... | Answered on Dec 29, 2008
This again, is set via the remote, in the on-screen menu.
Samsung VR3607... | Answered on Jun 04, 2007
check connections if ok possible interference if ok bad board
Samsung... | Answered 19 hours ago
you could do a force back light test .
Remove power cord, remove 1 side of the cable going between the main board and Power board. Plug in power cord and see if you get back light. The light should be on FULL since the main board is removed from the equation.
If backlight is fully bright then it could be the main board causing the problem. Any time you cant see main menu of the TV it also could be main board problem,
If you do force backlight test and the LED still do not look like htey are firing then it could be Power board or LEDs themselves.
Check voltage on CN802 and CNI801, proper low voltage should be listed there
Also CN201 pin 14 should be 1v-4v -> thats the diming signal
Samsung... | Answered Yesterday
The most likely cause is a problem on the power supply take a look at the power supply board if the capacitors are slightly bulged on top they need replaceing
Support - LCD TV LN-T4665F ' Samsung TVs
www.samsung.com > Home > Support
Samsung ElectronicsVisit Samsung today for LN-T4665F. You'll find product and support ... Manuals. UserManual ver.1.0 (EN,ES, 28.06 MB). Apr 26, 2011. Download (pdf)
Samsung... | Answered 3 days ago
Samsung VR3607 VHS VCR Logo
6 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
set timed recording
  • Televison & Video
