SOURCE: Fabric conditioner drawer full of water!
actully its considered normal the washer flushes the detergent,soap,and bleach with water when it overflowes it goes in the washer some water remaining is normal its in the owners manuel
SOURCE: Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
SOURCE: where do i put washing powder in hotpoint aquarius
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
SOURCE: Which compartment does the fabric softener go in
On the left side of the dispenser drawer is a grate with an embossed flower like object. Fabric softner goes in here.
