20 Most Recent Hotpoint Aquarius WMA56 Front Load Washer Questions & Answers
Have a fault with Hotpoint wma 58,keeps filling when cycle is finished this happens in intermittent burst, any ideas
You can go to google and put the brand-model #-and error code and find the error code meaning.
8/7/2015 1:24:06 PM • Hotpoint... • Answered on Aug 07, 2015
Why is the Pumping out get stuck in the middle?
Check the PUMP and its pipe are unclear and not blocked with items fallen from clothing being washed.
3/1/2015 2:37:28 PM • Hotpoint... • Answered on Mar 01, 2015
2answers
It wont do final spin..makes a clicking noise as
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
3/1/2015 2:29:41 PM • Hotpoint... • Answered on Mar 01, 2015
2answers
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
3/1/2015 2:28:15 PM • Hotpoint... • Answered on Mar 01, 2015
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
2/11/2015 6:31:31 PM • Hotpoint... • Answered on Feb 11, 2015
HOTPOIT AQUARIUS DOOR LOCK LIGHT FLASHERS
Faulty door interlock easy to fit cost parts about £15
2/2/2015 7:23:06 PM • Hotpoint... • Answered on Feb 02, 2015
F05 code on my washing machine
F05 - Pressure switch jammed on full.
9/22/2014 10:21:16 PM • Hotpoint... • Answered on Sep 22, 2014
0answers
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
1/23/2013 6:26:23 PM • Hotpoint... • Answered on Jan 23, 2013
Aquarius tcl770 started making noise then stop spining
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
1/22/2013 5:22:27 AM • Hotpoint... • Answered on Jan 22, 2013
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
7/20/2012 10:39:23 PM • Hotpoint... • Answered on Jul 20, 2012
2answers
Washing machine stopped working, flashing door
unplug for 3 minutes and replug to outlet and see if it has reset to memory.
7/15/2012 3:24:51 PM • Hotpoint... • Answered on Jul 15, 2012
Hotpoint Aquarius WMA56 Front Load Washer Logo
183 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
water leaking from bottom door our
  • Washing Machines
