1996 ford probe gt 2.5 5 spd will turn over wont start put new distributor in ran for 30 sec then nothing put another distributor in wont start fuel cutoff light on don't know what to do don't want to crush it plz help
You our not the only one dude I changed distributor timing belt and fuel pump and it still wont start.... I did get the code of 1345 to go away but still nothing....You our not the only one dude I changed distributor timing belt and fuel pump and it still wont start.... I did get the code of 1345 to go away but still nothing....
You can't post conmments that contain an email address.
Have you ever ran your car out of gas before? if so you may have killed the fuel pump. Did you bump something? make sure the fuel shutoff is pushed in, it's ether in the trunk on the right hand side above the wheelwell behide a metal plate it's red. drivers side kick pannle to the left of the petales.
possible fuel problem. start with the easiest,repl.filter. i think autozone or pep boys can check yuor pressure. a quick test is to see if it will fire with a shot of starter fluid
something to ponder over here as iam not sure what could be the problem here but if its a weak spark then it could be module /coil/crank sensor in that order .These problems will not show up as fault codes i dont think as they are working but not to full efficiency
Probes/Mazdas have issues with their distributor you might pull a wire and check for spark. There was one time i even had spark and still had to change the distributor, you might be able to find a local used solution instead of new just make sure they have some kind of warranty.
when you changed the water pump you need to make sure you change the timing belt also, did you do this. check that your timming is correct.
the other problem is different,
I would check to see if you are getting fuel at the correct psi, then how do you know you are getting spark, did you pull the plug and see the fire when you got it near a ground. also are the plug still good. you could have damaged your plugs. Is the distributor cap with rotor, and wires new? are you getting air. have you checked the timing? This is where I would start.
Sounds like bad distributor cap or rotor. If ones bad, might as well change both. Take off the cap and if there is a black color on the ends of the prongs, or on the end of the rotor, time to replace. Is it getting fuel into motor?
distributor is placed wrong for timing
take cap off unbolt distributor lift enough to turn rotor place back dont bolt litely just enough to hold distributor down without it poping up on you
place cap back on
now you need manual start and kill switch up in engine compartment turn vehicle over with manual starter switch if runs rough turn distributor till sounds good now time it with radar gun tighten bolts the rest of the way
now for what i described this has a margin of error going 1 to 3 notches to time in either direction from front to back or back to front turning of the distributor rotar
i hope i had made some sense here
or counter clockwise the lifting distributor and turning rotor one tooth to engine crank this is timeing
