Posted on Jun 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 042-326 - Xerox DocuColor 3535 Copier
Anonymous
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Jun 10, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
98429
Points
117
IBT/Transfer belt problem, requires NVM access to reset.
How to reset 042-326
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
How to resolve erreur code E000051-0000 whith canon ir 2800
the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
List of top Canon Pixma error E500 codes
Error code 1: Canon E500 Error Code E02 (E,0,2)
  • This error symbolizes that printer is out of paper or is incapable of feeding any document.
Error code 2: Canon E500 Error Code E03 (E,0,3)
  • This error signifies the Paper Jam.
Error code 3: Canon E500 Error Code E04 (E,0,4)
  • The error signifies that the "fine cartridge" is not installed accurately.
Error code 4: Canon E500 Error Code E06 (E,0,6)
  • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
Error code 5: Canon E500 Error Code E07 (E,0,7)
  • The ink absorber is complete and users need to reset the counter.
Error code 6: Canon E500 Error Code E08 (E,0,8)
  • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
Error code 7: Canon E500 Error Code E16 (E,1,6)
  • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
Error code 8: Canon E500 Error Code E17 (E,1,7)
  • The front tray is totally closed.
Error code 9: Canon E500 Error Code E30 (E,3,0)
  • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
Error code 10: Canon E500 Error Code E31 (E,3,1)
  • The machine is surely disconnected with the computer.
Error code11: Canon E500 Error Code E40 (E,4,0)
  • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
Error code 12: Canon E500 Error Code E50 (E,5,0)
  • Scanning of the print-head alignment sheet has failed to function
Error code 13: Canon E500 Error Code P02 (P,0,2).
  • This is a critical error which shows that the printer is in malfunctioning stage.
Error code 14: Canon E500 Error Code P10 (P,1,0).
  • This error signifies that the mechanical printer is in total malfunction stage.
So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
Go to
http://support.dell.com/support/0148
For further support as you have a hard drive error.
Hope this helps.
How to run PSA Diagnostics
Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
  1. Start the PSA Diagnostics
  2. Error Code List
Step 1: Start the PSA Diagnostics
  1. Restart the system.
  2. At the Dell logo screen, press <F12>.
  3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
  5. Write down any error codes listed.
  6. Use the list provided in the next section to see what the error code means.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
