You now need to add the WEP key to your wireless settings on your wireless device. Go to wireless networks, advanced network settings, find the name of your network, and add the WEP code, you will need to change the security settings to WEP.. That will fix your problem.
You can secure your wireless network wit WEP or WAP code. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 For belkin router http://192.168.15.1 or http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click
on wireless settings WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router. If you already set the code then if you can read it then you can ser it in wireless but if it is in 8 or # format then add new wep code . Then you can connect your wi fi network with that code. Thanks for using FixYa.
on wireless settings then enable WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Thanks for using FixYa.
You can secure your wireless network wit WEP or WAP code. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click
your password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Let me know if you need further assistance. Thanks for using FixYa.
The WEP number is a security code that is programmed into your wireless router through the web configuration page to prevent unauthorized access to your internet.
If this is your wireless network then you must have input the security code (its most probably 64bit meaning ten alpha-numeric digits).
If you're using 64-bit WEP Key, it would usually require you to put in 10 digits from 0-9 and A-F. so if you're putting in your wep key, make sure it's using only the characters 0,1,2,3,4,5,6,7,8,9, A,B,C,D,E,F.
