20 Most Recent Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Questions & Answers
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, Chrome etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode (whether to broadcast your SSID or not), change security protocol, password, etc.
Netopia... | Answered on Jan 05, 2015
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
Netopia... | Answered on May 29, 2014
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Netopia... | Answered on Nov 18, 2013
Reset the wireless by pushing and holding the RESET button, this will reset to default settings. Then you can reconfigure the SSID and Security. Take a look at this: http://www.routerpasswords.com/
Netopia... | Answered on Dec 23, 2012
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
Netopia... | Answered on Dec 29, 2011
Hello
Check with your router manufacture on how to log in to the router.
Once you have logged in,check that upnp or universal plug and play is checked to on.
This should allow x box to work through the router.
Netopia... | Answered on Oct 11, 2011
First make sure the dialling is done to the correct number - it will be listed in the contract papers.
Phone your ISP and request them to confirm you that those are indeed the correct username and password.
Netopia... | Answered on Sep 14, 2011
well, if you have been blocked by the admins of the website , u can still get an access to the website, as what the admins do is , they block ur IP, and hence u cant access it, if you want to get the access, then, change your IP address. to know How to change, it , u can mail me @ lokesh_b73@yahoo.co.in i can't publish it online. good luck
Netopia... | Answered on Aug 25, 2011
if you have the manual with the unit locate where is the reset button then push it for 10 sec.
Netopia... | Answered on Aug 04, 2011
You can put it onto tiles, so it will get at least a bit colder, but this is general problem of this routers, so I am affraid I am not going to help you.
Anyway, try those tiles, or some cooler enviroment
Netopia... | Answered on Jul 05, 2011
If you have a working Windows wireless machine, you can extract the key from the Windows machine and use it on your other devices.
Download this: http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html
and then run it.
You can learn the WEP or WPA key in use which you can then use on other devices.
If there are no other working wireless devices, you will need to log on to your access point and reset the password there. The instructions for that depend on your access point. For the Netopia, you can refer to the instructions at http://www.netopia.com/support/hardware/manuals/SoftwareUserGuideV761-Clsc.pdf
Netopia... | Answered on Apr 21, 2011
and then run it.
If using Windows XP: Go to Start/Control Panel/Switch to classic view/Windows Firewall/Turn off Firewall.
Windows Vista/7 Start/Control Panel/View By Large Icons/Windows Firewall/Turn off Firewall.
Netopia... | Answered on Mar 28, 2011
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
143 questions posted
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Netopia Computers & Internet
Most Popular Question
change nat open xbox 360
  • Computers & Internet
