20 Most Recent Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Questions & Answers
you should reboot the router and computer. also, check the connection. may be your router is not working fine.
https://www.askprob.com/forums/topic/why-is-my-belkin-router-not-working
Belkin Wireless... | Answered on Jul 11, 2019
This model printer has only an USB printer connection and normally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless network there are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a shared printer. Next connect the desktop computer to your wireless router with a LAN cable and then configure the wireless laptops to connect to the shared printer on the desktop computer. NOTE - This desktop computer and printer must be on at all times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to the wireless router with a LAN cable. The printer drivers needs to be installed on all the wireless laptops and then the printer port needs to be deleted from the USB port and a new IP address printer port installed. This IP address will be the IP address of the print server.
Belkin Wireless... | Answered on Jan 03, 2019
1 800 2BELKIN x2263
Belkin Wireless... | Answered on Oct 20, 2018
Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
Belkin Wireless... | Answered on Aug 29, 2018
BLU RAY :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the BLU RAY
Step 7: Get the IP Address of the BLU RAY
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the BLU RAY in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Belkin Wireless... | Answered on Aug 28, 2018
Do You have a problem with your Belkin Product? are you looking for Belkin Customer Support to Help you Troubleshoot your Belkin device? No Issues, We are going to Help you get the Belkin tech support in easiest way Possible. visit here : https://wirelessrouterexpert.com/customer-support/contact-belkin-customer-service
Belkin Wireless... | Answered on Aug 18, 2018
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Belkin Wireless... | Answered on Dec 04, 2017
Well you can try to contact to belkin tech support and ask for online assitance hope they will fix your problem and you will be good to go.
You can manually install it even without the setup CD , if you still have teh userguide you can find the steps there how to manually isntall it if you're having problem using the manual better call belkin support to help you manually setup that.
Hope that helps...........
Belkin Wireless... | Answered on Nov 18, 2017
That's about par for the course. This happens most everywhere and it needs to be reset. Upsetting I know, but most everyone has to deal with the same thing.
Belkin Wireless... | Answered on Sep 24, 2017
  1. Try plugging the router to a different power outlet.
  2. Reset the router.
  3. Check the power adapter specification of your router and if you have another power adapter that has the same specification then try that power adapter to your router.
  4. If using another power adapter and your router will not power on still, it is possible that your router is faulty already.
Hope this helps!
Belkin Wireless... | Answered on Jun 02, 2017
I DO HAVE THE CD BUT CAN NOT READ THE PIN ON BACK OF ROUTER I WAS GIVEN THE ADRESS #168..2.1 PLEASE HELP
LYNDA
Belkin Wireless... | Answered on May 09, 2017
IT means that the router has gone defective.
Belkin Wireless... | Answered on Apr 21, 2017
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Belkin Wireless... | Answered on Apr 20, 2017
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Belkin Wireless... | Answered on Feb 17, 2017
Access the built-in web-server software "inside" the router, and check the 'WAN' settings.
Contact AT&T, and ask for Technical Support, to verify that their router is working correctly.
Belkin Wireless... | Answered on Dec 30, 2016
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Belkin Wireless... | Answered on Oct 22, 2016
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
1,187 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
install belkin router without setup cd
  • Computers & Internet
