Ever heard of HP.com
ever heard of HP.com media install discs. or usb install sticks
ask HP, on HP can fix a bad OS,
its there system
there , OS, HP makes up there own matching windows 8 system disks that only run on your DV7-2277cl
do no use other disk.or it will fail,yes take it to town if this is not clear.
start hear,
get your disks from HP only or you will be sorry.
I promise. (there are exceptions but is GEEK level ,im not teaching ever)
BINGO HP.com (hard to remember no?>)
http://support.hp.com/us-en/products/
SOURCE: Every time I turn on my new PC I get a black
I have the exact same problem with my HP HDX 16. I would suggest calling the HP techcenter and exlaining the problem to them. Chances are they will want to take a look at it and will possibly replace your laptop. I haven't yet done this, but have allowed my computer to rest for a while. Leave it shut down for maybe 30-60mins and then try rebooting. Hopefully you will atleast be able to start it in safe mode with command promt. Open the command promt as the administrator and type CHKDSK which will perform a check for bad sectors in the hard drive. Hope this helps. otherwise give HP a call :)
SOURCE: HP dv7-2277cl Pavilion Notebook Have no sound
this might be because u r using an old version hdmi cable that only supports video...u need to get a new & more upgraded cable
SOURCE: Boot device not found Please instal l an operating
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
