20 Most Recent HP Pavilion dv6-1030us Notebook Questions & Answers
Are you sure it's not listed by another drive letter? Perhaps drive D?
HP Pavilion... | Answered on Dec 05, 2017
what mute? (ah Volume mute key)
no operating system stated, vista, XP , windows 7, or w10 upgraded
what? we cant NOT GUESS THIS. NO ONE CAN< blind.
BIOS is that screen that works, with the hard drive missing,
the minimum intelligence in the system. MIOS is better name.
when you boot and you see words on the screen those first words
like hit F1 for BIOS, or F9 or F10 or Escape.
that is BIOS talking to you,! all PCs do , 1984 to now.
BIOS actually boots the HDD or CDROM or a STICK USB
if you tell BIOS to do that, called configuring BIOS>
end bios 101 (im 69yo)
all we have here is MUTE button as INPUT,
I take it you never downloaded the HP manuals on this?
dv6-1030us
lucky you they are still there. as old as 2011 sys.
get them while still there, ring true ( IT Does for SURE)
RTM,. page 11 on first huge PDF "service GUIDE"
http://support.hp.com/us-en/product/HP-Pavilion-dv6-Entertainment-Notebook-PC-series/3837241/model/3860541/manuals
this #3 is the mute volume button (lamp too)
for this to work only the HP windows disks , used to install
fresh windows, works, MS did not MAKE YOUR MACHINE
HP DID !
Microsoft may not support this, , its a HP device only!
  1. so did you use the wrong disks to install windows.
  2. did you attempt to install drivers here ever? oops.
  3. to make this key work there are 2 paths.
  4. one path is install HP , op sys fresh, (you never stated yours)
  5. you install that and all works like new. end story.
  6. or path 2, vastly harder, using the HP page for your EXACT laptop and exact OS loaded (not MS but HP OS)
  7. you then install all related drivers., the can be 2 or 3 depending on what laptop you have and OS installed. on my HP
  8. the top panel seen below runs off a panel driver from HP.
  9. There are under lying chip drivers that must work first.
  10. so you go to DM , control panel device manager.
  11. and correct all yellow or red marked bad drivers first.
  12. Ill end there, i can not type every permutation of failure here, and the corrective actions step by step.... depends on whats wrong
  13. or if the laptop is INFECTED with VIRUS. and other factors.
  14. like others installing wrong drivers or wrong OS< etc.
mute-wlpfiktypqb3dki104wsq4vq-3-0.jpg why not join the real HP forum and ask there
and not on this silly chat forum.
fixya has zero structures to do that.
on real HP there are libraries of structure and cross linked
to the nth degree,
HP Pavilion... | Answered on Mar 28, 2017
plug in ethernet cable and go to windows update.It will offer the driver in a hardware update
HP Pavilion... | Answered on Aug 31, 2014
Just uploaded a manual. Hope this helps you.
Cheers
HP Pavilion... | Answered on Jul 26, 2014
You can try this,which works for many (not all) people>>
1.Right-click on "Computer" icon and select manage.
2.This will launch the Microsoft Management Console.
3.On the left side of the MMC, click on "Disk Management" and it will show you all of the partitions.
4.Right-click on the "HP Recovery" partition and select "Mark as Active Partition."
5.When the warning prompt appears, select "Yes" - Reboot and it will automatically boot into the Recovery Manager (without pressing F11).
HP Pavilion... | Answered on Jul 23, 2014
Try these websites:
www.techsupportforum.com > ... > Hardware Support > Laptop Support
www.driversdownloader.com/hp-drivers/hp-pavilion-dv2-1030us...
If that does not help - call HP, most of the time they will help without a fee.
HP Pavilion... | Answered on Jul 15, 2014
OS refers to Operating System such as Microsoft Windows or Linux or OS2 (IBM).
HP Pavilion... | Answered on Jun 06, 2014
Only if your operating system will not boot. Even then, with most modern computers you can boot to recovery files or installation programs on a USB or memory card.
Windows 7 USB DVD Download Tool available from Microsoft makes it possible to burn an image of an .ISO version of windows to a USB stick.
define it properly or it may be happen due to your monitor data cable problem
HP Pavilion... | Answered on May 23, 2014
http://www.soft-go.com/download_driver/HP-Intel-powered-Notebooks-WinFlash-BIOS-F.21-Rev.A_2275.html
HP Pavilion... | Answered on Feb 02, 2014
Well, by relying on this password recovery software, you can easily reset HP laptop Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Note: do not easily use your MS Windows recovery or boot CD as it may erase all data.
HP Pavilion... | Answered on Jan 03, 2014
It may be a hard drive error. Run chkdsk/f as soon as you are able and then check the registry for errors.
HP Pavilion... | Answered on Nov 06, 2013
try removing the battery and just having the power pack connected.
HP Pavilion... | Answered on Oct 30, 2013
Try removing the battery, disconnect the power cord. Remove any other devices such as USB devices. Hold down the power button for about 1 min. Release the power button. Connect the power cord only, not the battery. See if the laptop will power up. If not please let me know the indicator light flash pattern.
You have to disassemble it to replace the fan. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
HP Pavilion... | Answered on Oct 27, 2013
HP Pavilion dv6-1030us Notebook Logo
130 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
core temp
  • Computers & Internet
