Sounds like a battery or a battery cable issue.....Make sure battery is reading at least 12.6 volts and make sure cables are clean and tight....If it is good turn on switch and check all fuses.....
I really need more info....Is battery good ?...what size engine ? Is it only at ignition ?
Would love to help............... Metalpoet..........could be alternator........................
Check your battery and cables. will need a battery tester and auto voltmeter . test battery by dissecting both cables , and using battery tester hook positive to pos and negitive to neg, and check voltage , now check voltage with tester under load . hook cables back up and check for power at starter positive lead if not its a bad ground cable.
Check the battery cables from the battery to the main fuse block and to the starter and all the grounds. Have you tested the battery to make sure it has a charge?
