I highly recommend AOMEI Partition Assistant Server Edition to help you. You can use the function split, create, resize to partition your hard disk.
Here is the link:http://www.disk-partition.com/partition-manager-server-edition.html
If the computer is already running with Windows, then you can use a program called Partition magic to partition the C drive into two partitions - a C and a D drive.
If you are installing Windows from scratch then you can use the Windows installation CD to install Windows. When the Windows installation begins, delete the existing partition, then create a new partition but size the 1st partition (C drive) to what you require and continue with the installation.
When Windows has finished installing you can create the D drive by opening Control Panel - Administrative Tools - Computer Management - Disk Management - click on the un-partitioned portion of the hard disk, create a extended partition - and then format this partition in NTSF When completed Disk 1 will be shown as Healthy (system)
Further clarification required.
Kindly include the following information to complete your request:
Make, Model, Operating System, as well as information pertaining to the device...
Thank You, for choosing Fixya~!
