Keep your computer in the best shape as possible
By Christopher Thrash
B52COMPUTERS Most
computer users don't understand that core computer problems can be
avoided with little effort and pain. Let's look at some easy steps to
avoid those undesired meltdowns. Problems
that are associated with hardware, example would be a hard drive,
CD-ROM, or other internal parts of your PC, and software example would
be Quickbooks, Microsoft Office, Internet Explorer or anything that you
the user install's on the computer, can happen at the most haunting
times. That is something that can not be planed and is part of owning a
desktop or laptop computer, but most of the time that is not what
causes the ill-fated or sometimes evil problems computer owners deal
with. 99% of the time they are a result of user wrongdoing or
unawareness. So I will point out some steps so you can undo the unawareness part the wrongdoing you will have to work on. 1. Only install one anti virus program. 2.
Completely uninstall a malware program when installing a replacement.
My suggestion is maleware bytes and can be downloaded from filehippo.com for free. 3.
Clean the temporary files from your computer regularly. I'd suggest
after every session, no matter how short. This is best done with
CCleaner that can also be downloaded from filehippo.com and takes seconds if done regularly. 4.
Run regular full virus scans with your anti virus software. This will
ensure that any files you ve added to your hard disk are scanned and
clean, or removed if not. 5.
Avoid handling laptops with one hand when not in a carry case. This is a
common cause of dropped laptops, leading to failed drives and other
problems including screen damage. 6.
When plugged in, always use an anti surge socket with your laptop or
desktop PC. This is vital for protection of the delicate components
within. 7. Back up regularly. Data retrieval is a very expensive repair to have done and is probably the most avoidable. 8.
Shut down your computer properly. Avoid cutting the power at the plug.
Sudden power cuts can lead to corrupted and even dead hard drives. 9.
Don't open and attempt hardware repairs unless fully competent to do
so. Tampering with computers can turn a simple repair into a major
repair. 10.
If you do handle any of the internal components of a desktop or laptop
computer, make sure you are grounded against static discharge. This can
be fatal to your computer. when
you get into the situation where there are beginning signs of failure
such as random crashes and unexpected lock ups, first back up everything
that you want to keep on your computer to some kind of media that is
not a internal part of your computer This is really the most important
part of your regular routine as it's possible to save years of work and
memories from being lost with a simple back up. The one thing to bear in
mind about back ups is you should never backup to the same physical
drive you are using for your files. Having a backup on the same drive
means that if there is irretrievable physical damage, both the original
and the back up will be lost. Generally,
most people that use a computer will be guilty of doing one or more of
these preventive steps. The average computer user does not realize the
distress that lost data can bring into there life until it has happen to
them and then it is too late.
