20 Most Recent Brother MFC 420CN All-In-One InkJet Printer Questions & Answers
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Brother MFC... | Answered on Aug 16, 2019
mfc 465 brother unable to print
Brother MFC... | Answered on Jun 12, 2019
20 - Laser power error
Brother MFC... | Answered on Jun 04, 2019
Unplugging and leaving the printer powered down for ten to fifteen seconds can work wonders. Try it; you might like it.
Brother MFC... | Answered on May 21, 2019
Did you try replacing the cartridges? The accident might have damaged them.
Brother MFC... | Answered on May 06, 2019
You will need to take the scanner unit off and the cover tray. Many screws and clips to find and release. Once you have removed all that, you will find a container located just behind the cartridge bay that looks like it is full of black cotton pads - it is and that's the thing to very carefully remove. Use a bucket or laundry sink to remove the pads and note the order in which the are layered. Wash them out with water until the are relatively clean. Dry them and reassemble in order. Replace everything in reverse order and turn your machine on. You may need to run the maintenance code set again.
Brother MFC... | Answered on Nov 04, 2017
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
Brother MFC... | Answered on Oct 09, 2017
you might have multiple prints loaded
make sure you have the printer turned off it might load another page to be printed
you will need to open up a page you are about to print click ok
a page will open with a display print que tab
you will see all of the prints you have loaded
right click on the ones you dont need select delete
hope this helps
Brother MFC... | Answered on Dec 26, 2016
theres a wirestrip that moves it and if you check that it might start working or your rollers are jammed
Brother MFC... | Answered on Aug 12, 2016
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Brother MFC... | Answered on Jun 10, 2016
If you have unpluged the machine and repluged it in there is only one thing left apart from throwing it away: try to do a firmware update! download will be done from brother homepage. If youre lucky it will bing the machine back to work.
If that wont do, you have to put it away, sorry (circuitboard defective!)
Brother MFC... | Answered on Apr 27, 2016
Try just copying something on the machine. Does it print? If so, its a computer problem try setting up your prunter software again
Brother MFC... | Answered on Mar 29, 2016
Brother MFC 420CN All-In-One InkJet Printer Logo
1,373 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
keep getting error message unable clean
  • Office Equipment & Supplies
