You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Clean Cartridge Nozzles (Solution Center):
1. Go to Start, Programs(Windows
XP: All Programs), Lexmark 3300 Series, Lexmark Solution Center.
2. Click the Maintenance tab.
3. Click Clean to fix horizontal streaks.
4. Click Print. A cleaning page prints, forcing ink through the clogged
nozzles to clean them.
5. Print a document again
to verify that the print quality has improved.
6. If you are still not satisfied with the print quality, follow the instructions in this article How to Clean the Print Cartridge Nozzles and Contacts Manually.
i JUST WANt to clarify, the confirmation that you mention is that for FAXING? Like, after you receive or send a fax it will print a confirmation page that sending or receiving a fax is successful?
Please let me know.
adonscott
