You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
user ADMIN for login and leave password blank then you can connect using the wizards.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Solve this problem
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [FAILED]
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
