20 Most Recent Nintendo Wii Console Questions & Answers
This error code means that your Wii is unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings
You can find more troubleshooting to resolve this at Nintendo's help database: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nintendo Wii... | Answered on Feb 19, 2019
Try syncing the Wiimote again to reset the default position but otherwise it is probably a switch in the Wiimote that is going bad.
Nintendo Wii... | Answered on Feb 15, 2019
Here is a link to your error code.If you need more help than what they suggest,their number is there too.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=51330&system=Wii&locale=en_US&action2.x=7&action2.y=17
Good luck and game on!
Nintendo Wii... | Answered on Feb 14, 2019
According to Nintendo's website, this means that your Wii is unable to connect to your wireless network. Please try verifying you have the correct network name and password entered.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
although majority of games can play online, some game is still intended for single player only. Check the game options and see if there is multiplayer options to play online , majority of games for Wii can play online.
Nintendo Wii... | Answered on Feb 06, 2019
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Nintendo Wii... | Answered on Jan 28, 2019
try connecting the wii remote by taking the battery cover off and pressing the red button on the controller and the red button on the system at the same time
Nintendo Wii... | Answered on Nov 29, 2018
Nintendo provides many solutions in the link, hopefully one of them works.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32007&system=Wii&locale=en_US
All the causes of this error message should be able to be fixed by following one of these steps. Good luck.
Nintendo Wii... | Answered on Jul 11, 2018
does the cursor show up? have you been pointing towards the sensor bar? Are the batteries ok?
anke sure you check everything and anything. Take a break to think and check out something in the manuel if something's missing.
Nintendo Wii... | Answered on Jun 24, 2018
Try to attach it in another console or in a PC if it recognize it probably the issue is with your Wii.
Nintendo Wii... | Answered on Jun 16, 2018
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Nintendo Wii... | Answered on Jun 11, 2018
Yes and no. None of the regular guns can be given infinite ammo, but you can unlock special guns with infinite ammo.
Infinite Rocket Launcher - Complete the main game once to unlock this for use on a round 2+ playthrough of the main game. Cost = 1 million pesetas.
Chicago Typewriter (machine gun) - Complete Assignment Ada to unlock this for use on a round 2+ playthrough of the main game. Cost = 1 million pesetas.
Handcannon - Get 60,000 points on *all four stages* in Mercenaries mode with *all five characters* to unlock this for use on a round 2+ playthrough of the main game. Cost = free! However, you need to get it fully upgraded in order to have infinite ammo for it, which will cost about 770,000 pesetas.
Nintendo Wii... | Answered on May 04, 2018
According to Nintendo's website, error code 51332 means that your Wii is having a hard time connecting to your wireless network.
Make sure your router is working properly and that your Wii is configured properly for your network.
Nintendo Wii... | Answered on Apr 10, 2018
  • All saved data, game data, and downloaded channels will be erased. Once erased, this data can never be recovered.
How to Format the System Memory Wii and Wii mini Nintendo Support
Nintendo Wii... | Answered on Apr 01, 2018
Try changing your channel on the router to 11 or 1. For Linksys WRT54G routers enter the ip address of the router (default is 192.168.1.1) enter password and user name (default is admin/admin) then click wireless tab, now select a different wireless channel from the drop down box. Fix is not guaranteed to work for all consoles.
The WEP encryption has to be set on Key 1 in order for the Wii to recognize it. It's the same with the DS
I found a solution to this. I was able to pass the connection test, but I would fail during update with code 32002. The solution turned out to be to enter manually the ip address of DNS that my wireless router used. (via email, thanks jamh)
I had to change the MTU value from 0 (Default) to 1500 witch it was in the router for the Wii to finally connect and download the updates.
Hope this helps
Tom
Nintendo Wii... | Answered on Mar 31, 2018
no kelp available
you dropped it and damaged the internals
you take it in for repair or junk it
Nintendo Wii... | Answered on Mar 12, 2018
13,742 questions posted
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
Wii Nintendo
  • Wii Nintendo
Most Popular Question
error code 11182
  • Video Game Consoles & Games
