20 Most Recent Belkin (F5D7231UK4) Wireless Router Questions & Answers
After a thounder storm ,
sounds like you have to reset the router and put in your info again as when it was new ...
  1. Take a Ethernet cable and connect your modem from internet port of the belkin router and power on your modem.
  2. Take another Ethernet cable and connect your computer from Anyone empty Ethernet port of the belkin router. (if you have laptop then you may connect your laptop using wireless facility. You will find the username and password in the back of your router) .
  3. Now you need to power on your modem and wait for all lights to turn into green or blue lights. If all you have yellow light on your router. Then you need to restart your modem and wait for 2 minute. For more information you can visit : Belkin Router has solid orange light
  4. If you have solid green light on your belkin router, you need to go to your computer and open your browser.
  5. At the very top address bar you need to type the ip address 192.168.2.1 for opening the router setup page. (Sometimes the ip address may be different, you can check the router's ip address via running the ipconfig)
  6. Now you will be able to see belkin router setup page, so you need to click on detect my connection.
  7. If your computer will able to detect the connection properly then this will forward you to the wireless setup page. Here this will ask you to change the password (If you want) and click on next.
  8. Finally you will able to see all configurations window, so you need to check all configuration and click on save and continue to save all settings on your router. Now you belkin router will reboot and this will show you router admin page.
Finally your belkin router will setup and you will able to use the internet. you may try to connect the devices, whatever you want to connect with it.
2/12/2018 2:40:53 AM • Belkin... • Answered on Feb 12, 2018
0answers
Hi, I have a Belkin
Be the first to answer 5/11/2017 2:27:41 AM • Belkin... • Posted on May 11, 2017Be the first to answer
2answers
I suddently canot connect to
Hi i got your issue ....
Try with the following steps ....
Step 1: Connect modem>>computer
Step 2: Check whether you are able to go online
Step 3: If yes connect modem>>router>>computer
Step 4: Open the browser page and on the address bar type http://192.168.2.1
Step 5: Open the router page
Step 6: Towards the left column click on connection type just below internet wan
Step 7: Below the host name click on change wan mac address
Step 8: Now you will get an option clone computer mac address
Step 9: Click on that and then click on apply changes
Step 10: Now towards the left below wireless click on channel and ssid
Step 11: If asking for a password just leave it blank and hit submit
Step 12: Change the channel to 11 and click on apply changes
Step 13: Check with the connection
If u still have issues go to the link www.belkin.com/support
and download the firmware and try
For any queries contact 24/7 Belkin technical support 1800-2235546(toll free)
Thanks ......
With regards .....
Priya
4/3/2017 9:39:11 AM • Belkin... • Answered on Apr 03, 2017
0answers
I'm On my I-pod trying
press the button and allow the ipod to connect
3/6/2011 6:54:43 PM • Belkin... • Answered on Mar 06, 2011
After working for months, my
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
T
1/22/2011 12:50:19 AM • Belkin... • Answered on Jan 22, 2011
I have lost my cd
At Belkin : Support : Setup Assistant for Routers.
If you need more help come back.Post / thumbs / testimonial are welcome!
11/20/2010 4:46:22 PM • Belkin... • Answered on Nov 20, 2010
Im trying to set up
Connecting to the Internet using a router
  1. Choose a convenient location to begin installing your router, such as an open floor space or table. This does not need to be the permanent location of the router. For wireless routers, it may be necessary to re-position the unit after installing it as the signals may not reach all areas needed.
  2. Unplug the power to your Internet modem.
  3. Power down your computer(s).
  4. Plug the power in to your router.
  5. Connect your Internet modem to the router. The cable plugs into the router jack named "WAN" or "Internet". Turn on your Modem.
  6. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable.
  7. Turn on the computer.
  8. From the computer connected to the router, open your web browser. Enter the router's address, http://192.168.2.1, and press Enter on your keyboard.
  9. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  10. To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
  11. If this is a wireless router, change the network name (referred to as SSID). While the router comes to you with a network name set at the factory, you may want to use something more familiar for your network. Read Changing the router's wireless channel and SSID for a description of this process.
  12. Plug the power back into your Internet modem.
  13. Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
  14. Finally, configure additional network security features as desired to guard your systems against Internet attackers.
11/19/2010 12:26:30 PM • Belkin... • Answered on Nov 19, 2010
I need the code on
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
10/20/2010 4:11:05 PM • Belkin... • Answered on Oct 20, 2010
The settings saved on
9/26/2010 6:04:04 PM • Belkin... • Answered on Sep 26, 2010
Yesterday I hooked up our
change the Wireless Network Security Authentication to WPA-PSK and u should b fine now
8/12/2010 12:20:04 AM • Belkin... • Answered on Aug 12, 2010
I have a belkin F5D7230-4 and cant connect online
type your password in word pad or notepad to verify that you are typing the correct password. You may have you caps lock on.
5/8/2010 2:39:24 AM • Belkin... • Answered on May 08, 2010
How do secure my belkin router from other users?
HERE are the instructions for setting up the wireless encryption for your router
4/16/2010 12:53:34 AM • Belkin... • Answered on Apr 16, 2010
Wi fi not working, only cable. whot i have to do ?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
2/23/2010 1:40:06 PM • Belkin... • Answered on Feb 23, 2010
No internet connection when its hooked up
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
1/23/2010 10:56:04 AM • Belkin... • Answered on Jan 23, 2010
I have a belkin wireless router and i reset it and
Connect the Router - Computer (Wired)
And Run the CD
1/7/2010 10:42:41 PM • Belkin... • Answered on Jan 07, 2010
Belkin (F5D7231UK4) Wireless Router Logo
Popular Tags
41 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
im trying set up
  • Computers & Internet
