1994 Dodge Intrepid Logo
Posted on Feb 25, 2011
Break system boster . the part thats connected to the peadle has seal that is broken. i need to know the name of the part and how to replace it.
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Feb 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
14753
Points
86
The name is exactly that "Brake Booster" To remove it: Remove the master cylinder assembly and vacuum hoses from the booster. On the interior side of the firewall you will have to unbolt the booster and disconnect the linkage attaching the pedal to the piston in the booster.
2001saturn pulsating breaks
if it is in the brake peadle only you need to replace the rear drums/ rotors if you feel it in the streeing wheel it will be the front rotors
1995 gmc suburban leaking power steering fluid at end of I think is steering column that hooks to something else but there is rubber seal like that is breaking apart that connects the 2 parts together? I...
Sounds like the pitman arm. See #5 on diagram below. It has a ball joint with grease that is held in with a boot. It the boot is cracked open, you should replace the arm. You will need an alignment after replacing the arm. The arm does not contain any steering fluid, so if that is leaking, you have another seal broken somewhere...
Change breakbooster no breaks
if you have put in a boster or we call it a servo in uk it will need a complete bleeding of the break system to make sure all the air is out also make sure the vacume hoses are all conected as this is how it works from presure from the engine
Above the oil filter is a black box shaped thing that needs a seal and that seal is broken and needs to be replaces i need to know the name of what i am looking for and maybe a price range and how to pif...
The black box is an oil cooler for the engine. Its just a big o-ring sandwiched in between the flange and the oil filter. Should cost much more than 5 bucks for the o-ring.
2answers
Brakes start working very low in the pedal. abs light comes on from time to time.
The low pedal is for the most part, worn front pads
The check light and ABS is a System malfunction,
common is a Wheel Speed Sensor
Need codes, then diagnose.
Best bet is a repair shop
If you always work on your own vehicles, we may be able to
give some guideance
Dont know how to replace brake light switck
Remove the cover from under the dash and look up above the brake peadle about 5 inches you should be able to see the switch there may be 2 switches if you have cruse contronl. The brake light switch should have white and orange wires. just pull back on the switch to remove it. When putting the new one in push the brake peadle in then push the switch all the way in the hole then pull the brake peadle back till it stops this will push the switch back out some this will adjust the switch. Of course ckeck for proper operation. Here is a bad diagram of the switches but it the only one I could find.547561f.png
Change break fluid and boot at break boster break paddle hard to push
replace the brake booster. the vacuum assist isnt working thats why its hard to push the brake pedal, check the booster and see if its leaking air.
2helpful
2answers
Break peadle wont hold pressure
U are going to need a new brake master cylinder, the internal seals are leaking and allowing the fluid pressure to leak down, this why the sinking pedal
2answers
I replaced all rear bulbs and i still have no lights when i hit the brakes
If they work when the turn signals or the hazards are on then you need to replace the brake light switch on the brake pedal bracket.If the lights don,t work on hazards but do with the turn signals,then you have a fuse blown.If none of the above work then you need to check the wiring under the truck box for a bad plug in connection,corrosion or broken wires.
Peadle goes to the floor with no pressure behind the pedel fluid
you will need to replace your master cyl and bleed your brakes
your master cyl is bypassing inside or the seal are bad inside the master cyl
there isnothing slse in the system that could cause this unless you are loosing fluid.
good luck
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
