If when you push the air button it will not turn off the pump, it may be the button that is bad on the top of the tub or the air switch located in the motor.
take the pump out and plug it into an outlet. get a straw and blow into the air switch with the pump plugged in still. if it comes on then the button on the top of the tub is bad. if it doesn't come on then the air switch is bad.
SOURCE: I have a whirlpool jacuzzi tub. I wired to diagram
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
SOURCE: I have a Jacuzzi Aero Select Tub, everytime i
Run an extension cord from another gfci and see if it works. If so, you could have a faulty gfci or issues internally to the motor. Also, if the "home run" for the tub is wired into a sub-panel and the grounds and neutrals are not isolated it could cause problems with a gfci as well.
Hope this helps!
Mike
