20 Most Recent Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T715 Questions & Answers
Study positioning of remaining clip and emulate with the one that fell off. If something broke then you may have to do a Rube Goldberg - a good epoxy might just do the job.
Jacuzzi Amiga,... | Answered on Aug 24, 2017
Stems are removed from the top of the valve. With handle removed, use an appropriate wrench to unscrew it.
Jacuzzi Amiga,... | Answered on May 26, 2017
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
Jacuzzi Amiga,... | Answered on Jan 12, 2011
should be able to either push down or up on skirt..has clips that hold it together bottom or top>>are longer shorter to allow movement
Jacuzzi Amiga,... | Answered on Dec 31, 2010
Use a rubber stopper measure diameter of hole 1 inch,,,1 1/4 inch,,,???
Jacuzzi Amiga,... | Answered on Nov 29, 2010
turn the temperature up on the topside panel. if it is wired 220v then it will get to 104 deg in about 3 hrs
Jacuzzi Amiga,... | Answered on Nov 15, 2009
Go on searc and enter the manfasturer, model and manual. see what pops up.
Jacuzzi Amiga,... | Answered on Nov 10, 2009
Thermostat calibration is suspect
Jacuzzi Amiga,... | Answered on Oct 10, 2009
You should be getting error messages like flo or FLO2. check the voltage to the pump from the board if power is there the pump is bad and needs replacing
Jacuzzi Amiga,... | Answered on Aug 19, 2009
You will have to contact the manufacturer for a service manual for your unit. Do you have an access panel. Usually the apron can be removed for easy access. Also, on some units the trim around the switch can be screwed off and the tubing accessed that way.
Jacuzzi Amiga,... | Answered on Apr 06, 2009
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
Jacuzzi Home | Answered 2 days ago
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
Jacuzzi Home | Answered on Feb 10, 2019
Jacuzzi Amiga, Soaking Bathtub with Integral Skirt - T715 Logo
Popular Tags
17 questions posted
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
plug part
  • Home
