20 Most Recent
Jacuzzi Bellavista 6 Whirlpool w/2-Speed Motor JAC-EE20 Questions & Answers
Jacuzzi tub. Runs pump. Turn
What kind of controls do you have? Electronic it sounds like but do you have a model number of the control box under the tub?
2/15/2011 5:15:39 AM •
Jacuzzi...
Answered
on Feb 15, 2011
My Jacuzzi Bellavista tub runs
You have a bad circuit in the system. It has probably gotten hit with a power surge or power spike and partially knocked out a circuit. now it cycles on/off at any given time during the day.
You will want a Jacuzzi Service Tech to come out an change that for you.
2/3/2011 11:59:35 PM •
Jacuzzi...
Answered
on Feb 03, 2011
High speed on pump motor just hums then trips
possibly trying to draw more power than the breaker and wiring are rated for.. check maximum amperage draw from motor, then check breaker.
If breaker is rated lower than High speed amperage draw, then have a qualified electrician install proper size of wiring and breaker.
If not, then the high speed coil of motor may be defective, check for warranty of unit.
8/2/2010 10:31:50 PM •
Jacuzzi...
Answered
on Aug 02, 2010
Our Jacuzzi Espree 6060 corner whirlpool stopped
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
6/3/2010 5:02:39 AM •
Jacuzzi...
Answered
on Jun 03, 2010
Cleaned & filled tub after winter shutdown.
Hello. open up the mechanical compartment where that pump and it's control box are located. There are usually two reset buttons in there that often kick off. Push the reset and you should be ok. Joe
3/23/2010 12:22:00 PM •
Jacuzzi...
Answered
on Mar 23, 2010
I have a Jacuzzi Aero Select Tub, everytime i
Run an extension cord from another gfci and see if it works. If so, you could have a faulty gfci or issues internally to the motor. Also, if the "home run" for the tub is wired into a sub-panel and the grounds and neutrals are not isolated it could cause problems with a gfci as well.
Hope this helps!
Mike
2/2/2010 4:10:01 AM •
Jacuzzi...
Answered
on Feb 02, 2010
Motor always on...never turns off anymore after
may be in default setting for filter time if unit loss power temp and filter reset to a default mode usually 95 degrees and 6 hrs every 12 hrs most people forget to reset the filter time
11/1/2009 1:20:07 PM •
Jacuzzi...
Answered
on Nov 01, 2009
My jacuzzie motor just clicks and won't turn on.
Look behind the tub cover, it should have one. You should be looking for a GFCI it sounds like. These are the outlet that you generally have in your kitchen. They have a reset button and it just sounds like it needs to be reset.
8/18/2009 3:55:35 AM •
Jacuzzi...
Answered
on Aug 18, 2009
My brand new jacuzzi bathtub motor just clicks and
check 2 things......1) see that the power is connected and that the breaker is on.......2) if everything from 1 is a yes check the hose that runs from the switch to the motor it may be lose, disconnected or has a hole in it. If you have anymore questions just ask. I am a professional plumber for over 25 years
7/31/2009 2:46:00 AM •
Jacuzzi...
Answered
on Jul 31, 2009
Motor buzzes, like it's resetting but never stops
It sounds as though the motor is about to go out. If you have access, try and lubricate the shaft using a zoom spout oiler. Its just a little bottle of oil with a long thin spout like on a can of wd-40. Look around the motor houseing to see if there are any lube holes too but I doubt there are any. Maybe this will help.
3/22/2009 1:22:57 AM •
Jacuzzi...
Answered
on Mar 22, 2009
The on off light in my Jacuzzi whirlpool bath keeps flashing
The flashing on/off light in a Jacuzzi whirlpool bath may indicate an issue with the control system, and it's important to address the problem to ensure the proper functioning and safety of the whirlpool bath. Here are some general steps you can take to troubleshoot the issue:
1. Check the Power Supply:
- Ensure that the whirlpool bath is receiving power. Verify that the circuit breaker for the whirlpool bath is not tripped, and check for any loose or disconnected power cords.
2. Inspect the Control Panel:
- Examine the control panel for any visible issues, such as loose or damaged wires, connectors, or buttons. Ensure that there is no water or moisture present in the control panel area.
3. Reset the System:
- Some whirlpool baths have a reset function. Turn off the power to the unit, wait for a few minutes, and then turn it back on. This can sometimes reset the control system.
4. Refer to the User Manual:
- Check the user manual that came with your Jacuzzi whirlpool bath for specific information on troubleshooting and resetting the control system. The manual may provide insights into the meaning of the flashing light and how to address it.
5. Contact Jacuzzi Customer Support:
- If the issue persists and you cannot find a resolution through the manual, contact Jacuzzi customer support or the manufacturer for assistance. They may be able to provide guidance on how to troubleshoot and resolve the issue.
6. Professional Inspection:
- If you're not comfortable or able to identify and fix the issue, it's advisable to seek assistance from a qualified professional or a technician experienced in Jacuzzi whirlpool bath systems. They can perform a thorough inspection and diagnose and repair any electrical or control system problems.
It's essential to prioritize safety and follow proper procedures when dealing with electrical components and water. If you're uncertain or if the troubleshooting steps don't resolve the issue, it's best to seek professional assistance to avoid potential hazards.
12/17/2023 11:37:18 AM •
Jacuzzi Home
Answered
on Dec 17, 2023
